quick gas info... #559225 01/27/05 08:07 PM
O
OffRodEO Offline OP
Any watch the History Channel? Oh i love that channel.
yesterday (jan 26) they have a show called Modern Marvels. On yesterdays episode, they explained how they make gas. It is very interesting, i cant explain it all, but the basics of it. They get the crude oil and boil it at around 700*F., from bottom to top here is what is made out of boiling it. tar, thick oil (the kind you put in your car), thinner oil,gas (the kind we use) then gases that ecscape from the top. 3/4 of the way up is an outlet so the gas can drain out. In a normal barrel of crude oil,50% of it is acually made into gas.
When you go to the gas station you see 87 89 or 91 (depending on state) that means 87,89, or 91 percent octane, and 13,11, or 9 percent heptane. Octane is the anti-knock property and is stable at a moleculare structure. Heptane is very unstable (pre-ignites real easy) but burns cleaner. Back in the day they used lead to improve the anti-knock, but due to regulations on air quality, it was stopped a while ago. So, when you go to get gas, get the cheapest one and if it knocks, go to the right gas or what is recommended by the manufacturer.
So, if anyone always wondered about gas like i did everytime i went to fill up, here is a breif discription on it. Also check this out on how and why gas prices go up and how we are affected.
Info on gas price fluxuation
enjoy
kevan
93 rodeo,3.2 manual, limo tint, nice sound system,keyless entry and a killer alarm, drop in K&N, 3 inch DOR lift, 32-11.50 BFG MT's, warn hubs zutah.com wheeler
WELLS FARGO BANK WILL RIP YOU OFF!GET OUT WHILE YOU CAN
Re: quick gas info... [Re: OffRodEO] #559226 01/27/05 10:48 PM
8
89YellowAmigo Offline
i always thought lead was used for lubrication <img src="/forums/images/graemlins/confused.gif" alt="" />
'89 Amigo, 2wd
2.3L
Re: quick gas info... [Re: 89YellowAmigo] #559227 01/27/05 11:19 PM
Z
zKnightWhoSaysNi Offline
that's what i thought also. I understood that running unleaded in an unleaded eng would burn up the valves which were softer in the leaded engines. may be wrong, but thats what i remember from my vw bug and mustang.
'99 Trooper, 912's
'89 Trooper RS, 2.6
Re: quick gas info... [Re: zKnightWhoSaysNi] #559228 01/27/05 11:30 PM
W
Wayne Offline
Not picking on you, just adding more info.
We've discussed it before in the thread located here.
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: quick gas info... [Re: Wayne] #559229 01/27/05 11:36 PM
O
OffRodEO Offline OP
nice never seen that thread. That explains all what i seen, well most of it, especailly about the hydrocarbons. But, they did say they put lead in there to increase the anti-knock properties.
kevan
Re: quick gas info... [Re: zKnightWhoSaysNi] #559230 01/28/05 08:47 PM
RodeoXS Offline
... I understood that running unleaded in an unleaded eng would burn up the valves ...
God I hope not, thats what I put in my unleaded engine <img src="/forums/images/graemlins/smile.gif" alt="" />
George <img src="/forums/images/graemlins/nana.gif" alt="" />
92 Rodeo XS 4x4
HomePage
Re: quick gas info... [Re: RodeoXS] #559231 01/28/05 09:11 PM
Z
umm... oops.
that's unleaded in leaded use engine.
so much for previewing before posting.
'99 Trooper, 912's
'89 Trooper RS, 2.6
Re: quick gas info... [Re: zKnightWhoSaysNi] #559232 01/28/05 09:31 PM
RodeoXS Offline
Knew what you meant...just ragging on you.
Checked out your link in sig....the Rodeo pic links say under construction. Got any to share? Like to see your Rodeo.
92 Rodeo XS 4x4
HomePage
Re: quick gas info... [Re: RodeoXS] #559233 01/29/05 01:04 AM
Z
every time i think about taking a pic, it's raining. and of course as a california boy (ragging on myself) i can't go out in the rain and get wet. And when it's been nice, I've been busy doing lifes busy things. I'll get some posted as soon as I can. i did the web site quickly as a medium to post pics of the RS when we bought it, and added dead links for the rodeo for later use. I guess it's later now.
'99 Trooper, 912's
'89 Trooper RS, 2.6
PHP: 7.4.33 Page Time: 1.625s Queries: 15 (0.003s) Memory: 0.6306 MB (Peak: 0.7341 MB) Data Comp: Off Server Time: 2026-05-29 17:11:28 UTC
