Which pins are the timing jumper? #559237 01/27/05 08:31 PM
W
wave Offline OP
I am trying to adjust my timing. My FSM hasn't made the move yet and is 130 miles away.
Where is the timing jumper located on a 95 runner 3vze, and which pins do I jump?
IIRC I am looking for 8 deg before TDC jumped and 12 deg before w/out the jumper.
Thanks for the help guys!!
Anthony
Re: Which pins are the timing jumper? [Re: wave] #559238 01/27/05 09:12 PM
4Crawler Offline
Re: Which pins are the timing jumper? [Re: wave] #559239 01/27/05 10:36 PM
W
wave Offline OP
Thanks Roger! So the jumper for the error codes is the same one used when setting the timing? Just making sure I don't screw things up to bad!
Anthony
Re: Which pins are the timing jumper? [Re: wave] #559240 01/27/05 11:15 PM
4Crawler Offline
I think so, it is on my '85 and also on a '94 that I tested.
If you put the jumper in and the timing does not change, then it is eitehr the wrong pins or the TPS IDL-E2 setting is off:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Re: Which pins are the timing jumper? [Re: wave] #559241 01/30/05 10:46 PM
W
wave Offline OP
That was the one! Thanks Roger!! My timing was at about 2 deg after TDC when I checked it. I set it at 10 deg before TDC. It cranks a little smother and I got close to 16 MPG at 80 w/ two kayaks on the roof. Much better.
Thanks again!
Anthony
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6055 MB (Peak: 0.6696 MB) Data Comp: Off Server Time: 2026-11-19 00:15:09 UTC
