Floor jack position for 3" suspension lift
#559285
01/27/05 09:45 PM
Where do you guys position the floor jack for the front of the Tacoma? The user's manual showed the spot, but I need to save them for the floor stands. How is about for the rear?
Re: Floor jack position for 3" suspension lift
[Re: TCAO]
#559286
01/28/05 12:18 AM
I used a floor jack in the center of the front cross member for the front and did one side at a time. Then I jacked the rear of the truck and positioned the stands on the frame so the axle can be dropped down to install the blocks. Do one side of the rear axle at a time as well to keep from having to fight the axle back into position.
John Luttrell 2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5862 MB (Peak: 0.6339 MB) Data Comp: Off Server Time: 2026-05-30 16:55:51 UTCValid HTML 5 and Valid CSS
