Turn signal flasher for 97 T-100
#560280
01/30/05 12:20 AM
Greetings Everyone, I'm new here but have already used a lot of your suggestions. The turn signal and flashers on my 97 T-100 abruptly quit working. I thought I would change the flasher but I can't find where it's located. Had half the dash apart, went to dealer and they had quick look, one said his (on a 98) was behind the fuse block - looked there, I don't think there's enough room. Someone mentioned it's under the hood - none of the part numbers of the relays I saw seemed to match. WHERE IS IT???????
Bob's 97
97 T-100, 4WD, bone stock except for MP3 player/radio 80 CJ5 Jeep (Trigger) w/ 225k miles and so rusted that tetanus shot required to ride in it
Re: Turn signal flasher for 97 T-100
[Re: bobs97]
#560281
01/30/05 12:53 AM
The Haynes manual says it is behind the panel under the instrument cluster. I think there are about 4 bolts to take out and you'll have access. It is the panel on the dash directly below the steering wheel and the flasher is supposed to be on the left hand side.
97 T100, 32" BFG/AT, Warn hubs, stock height with Bilstein shocks, Optima battery
[Re: NYT100]
#560282
01/30/05 01:33 AM
I have that manual and had that left lower dash panel off. Also took of the trim around the gage cluster. Unless it's behind the AC duct which I felt around top and bottom, it just aint there.
Bob's 97
[Re: bobs97]
#560283
01/30/05 01:58 AM
Yeah, I wish I had a better manual than the Haynes. Maybe someone here has the Toyota Factory manual and can tell you exactly where it should be.
[Re: bobs97]
#560284
01/30/05 06:56 AM
I'm looking at my downloaded Factory service manual and it shows the flasher as in the cab, Just to the right of the hood release. I also have a 97 and downloaded all '97 stuff so this should be accurate.
Hope it helps...
Cheers,
Brian M '97 T100 SR5 4x4, with Buckets
[Re: Brian_M]
#560285
01/30/05 07:11 PM
Did you check the blinker fluid? Could be running low.... <img src="/forums/images/graemlins/notooth.gif" alt="" />
'97 T100 SR5 XCab 4WD TRD SC ~ ARB ~ FWC '85 FJ60 Landcruiser 4E9 ~ locked ~ 33's
[Re: Brian_M]
#560286
01/30/05 07:17 PM
If I'm reading my 95 FSM correctly, it's on the auto shifter shaft (black relay behind the white connector): Closer: ![[Linked Image]](http://myweb.cableone.net/jlflanagan/Autos/T-Flasher-s.jpg)
[Re: JohnF]
#560287
01/30/05 08:20 PM
Thanks for the pics, that's what I needed to see. Mine has the factory alarm which apperently also wires into the turn signal flasher but I did find this same relay tie-wrapped about 3" above the fuse block. It has 5 prongs, the replacement AutoZone sold me only had 3 so I was looking elsewhere. It's not the same part number Toyota wanted to sell me for $56 either. I pulled the relay off and tried to start the beast, it won't start without that relay installed. (alarm or ??). I'll go back to dealer tomorrow and see what parts department has to say other than 'Will that be cash or do you need to take out a loan?'. Thanks for everybody's help, you would be suprised how many people in Houston misinterpret hand signals.
Bob's 97
[Re: bobs97]
#560288
02/01/05 07:19 AM
...you would be suprised how many people in Houston misinterpret hand signals. Sad thing is, I probably wouldn't be all that surprised... <img src="/forums/images/graemlins/pfft.gif" alt="" />
4xGeek (Chris) '97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc... No longer stuck in SoCal!!
