2.8 GM V6 intake manifold interchangability? #560783 01/31/05 06:08 AM
Pyro4117 Offline OP
Are the TBI intake manifolds for the 2.8's all interchangable?
I have a lead on one that I would like to have bored out to match a 4.3 throttle body to reduce the out of service time when I swap, but it has a different part number. It's off a '90 S-10, but it looks identical to the one on my '91 Trooper (well, as much as I can tell without taking mine off and setting them side by side).
Is this just a GM/Isuzu part number difference, or are there other quirks to look out for?
TIA
Jay
1991 Trooper - DEAD! 2.8 V6, 5 spd, 4WD, HD clutch, 2.25" exhaust, EPROM Chip, KC/Hella, Aisin hubs, Rancho 9000X's, Panasonic/Infinity/Alpine
My Pics
Re: 2.8 GM V6 intake manifold interchangability? [Re: Pyro4117] #560784 01/31/05 06:19 AM
Jim_Paget Offline
This may be an urban myth, but try dropping the first and last number of the Isuzu part number, and you may find the Chevy number.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: 2.8 GM V6 intake manifold interchangability? [Re: Pyro4117] #560785 01/31/05 06:23 AM
onebadtrooper Offline
yeah man I'm pretty sure they are the same. I heard if you take the gm part number, and take the first and last number off, and thats the isuzu part number.Or the other way around? But i'm like 98% sure there the same manifolds <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 2.8 GM V6 intake manifold interchangability? [Re: Jim_Paget] #560786 01/31/05 04:21 PM
G
GKreamer Offline
Not an urban myth IMO, I have ordered alternator braces for my 2.8L V6 when the braces broke and the Isuzu parts guy gave me the Isuzu parts number and told me to drop the first and last digits. I did so and ordered the parts faster and cheaper thru the local Chevy dealer. AFAIK, this would only apply to engine parts on the GM 2.8L. This also worked on a replacement Power Steering resevoir and oil filler cap... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 2.8 GM V6 intake manifold interchangability? [Re: Pyro4117] #560787 01/31/05 10:36 PM
Pyro4117 Offline OP
Well, the part # theory didn't help. The part # on the one for sale is 14089802, mine is 10087672.
If it was a little cheaper I might take a flyer on it, but it's off eBay (typical small fuzzy pics), so maybe I'll keep cruising the junkyards to find one I that I can compare in person to mine.
Thanks,
Jay
My Pics
Re: 2.8 GM V6 intake manifold interchangability? [Re: Pyro4117] #560788 02/01/05 05:02 AM
barak Offline
whats the average rate for the 4.3?And does it fit the 2.8 or only the 3.4?
Re: 2.8 GM V6 intake manifold interchangability? [Re: barak] #560789 02/03/05 01:15 AM
CPOM Offline
Do a search under my username under 4.3, I did a writeup that can answer some of your questions.
CHRIS
98 Amigo, 92 Pup
Re: 2.8 GM V6 intake manifold interchangability? [Re: Pyro4117] #560790 02/03/05 01:52 AM
barak Offline
If I can't get a 3.4 right away , I think I might swap the 2.8 in , just to get rid of the worst of it , make it alittle easier later on.If I have the 2.8 in , could I pick up a 4.3 TB and put it on the 2.8 untill I find a good 3.4?Or will it only work on a 3.1 or 3.4?
Also , do I need the 4.3 intake manifold too and other parts for the 4.3?
Re: 2.8 GM V6 intake manifold interchangability? [Re: barak] #560791 02/03/05 04:14 AM
CPOM Offline
please do a search under my username under 4.3, I did a writeup that can answer some of your questions.
CHRIS
98 Amigo, 92 Pup
Re: 2.8 GM V6 intake manifold interchangability? [Re: CPOM] #560792 02/03/05 06:07 AM
barak Offline
I read your write up , but all I saw mentioned in it were the 3.1 and 3.4 , thats why I was asking if the 4.3 TB works on the 2.8 as well <img src="/forums/images/graemlins/smile.gif" alt="" />I can't afford 2700 right now for a new 3.4 , so will use the 2.8 till I can find a good used one or have the cash for a new engine.
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6391 MB (Peak: 0.7588 MB) Data Comp: Off Server Time: 2026-07-13 23:19:45 UTC
