Turn Signal Flasher location on 97 T-100 Mystery Solved #561307 02/01/05 03:46 AM
bobs97 Offline OP
Had to spend some $$ to find out where but the Turn Signal Flasher is actually located approximately behind the fuel gage. If you look upwards with your head laying on the brake pad, you should see 2 relays - the lower most one with a thin supporting brace hooked in the top is the turn signal flasher relay. It has 3 prongs, has the word 'flasher' printed on it and if original, will be part #81980. No need to take any of the dash apart to get at it.
The picture that JohnF submitted of a relay on my original posting was ID'd as an alarm relay by the good folks at Toyota parts. (I pulled the one off mine and took it in)
Anyway, I put the new flasher in, topped off the blinker fluid and the turn signals worked fine.
Bob's 97
97 T-100, 4WD, bone stock except for MP3 player/radio
80 CJ5 Jeep (Trigger) w/ 225k miles and so rusted that tetanus shot required to ride in it
Re: Turn Signal Flasher location on 97 T-100 Mystery Solved [Re: bobs97] #561308 02/01/05 06:34 PM
NYT100 Offline
I'm glad you got it figured out and it's working again.
97 T100, 32" BFG/AT, Warn hubs, stock height with Bilstein shocks, Optima battery
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5845 MB (Peak: 0.6325 MB) Data Comp: Off Server Time: 2026-06-21 11:17:17 UTC
