power steering pump rebuild #56258 06/19/03 05:36 AM
tkrispin Offline OP
Who has done a power steering pump rebuild, and what was the level of difficulty? Is there a rebuild kit from Toyota??
I want to rebuild my celica's p.s. pump, I'm tired of pouring fluid in it every 2 weeks.
Sorry for the general questions, I got tired of searching...
Tom -|- TLCA #12384 -|- '95 4x4 x-cab mini
Finally E-locked...
1987 Celica GTS liftback - stock for now
...never enough...
Re: power steering pump rebuild #56259 06/18/03 09:40 PM
I don't know about the V6 pump, but there is a rebuild kit for the pump on the 22R/RE engine. It's just seals and O-rings, you have to order the bearing seperately. I just ordered both of them the other day, but I haven't started on the job yet.
Re: power steering pump rebuild #56260 06/20/03 05:16 AM
tkrispin Offline OP
Thanks for the response. I assume you ordered the parts from Toyota? I'm not worried about my v6 pump just yet, the celica pump is leaking like a barrel full 'o holes right now. I guess it would be similar to the 22re pumps....
Finally E-locked...
...never enough...
Re: power steering pump rebuild #56261 06/20/03 05:20 AM
OOP'S Offline
Did the one on my V-6. Not that hard just make sure you install the seals as they are marked. Also make sure that you use ATF and not power steering or you will be rebuilding again. If you have been putting Power steering fluid in, purge the system and refill with ATF>
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.009s Queries: 14 (0.007s) Memory: 0.5951 MB (Peak: 0.6532 MB) Data Comp: Off Server Time: 2026-11-15 15:47:40 UTC
