Two stupid questions... #563602 02/06/05 01:12 AM
TacoYota Offline OP
1) What year did Toyota switch from the horizontal front grill to the vertical?
2) Is it safe to assume that the keyless entry system on an '04 does not double as an alarm?
Thanks!
2004 Tacoma Xtracab 4x4 V6
JL Audio sound system
** Caution: Video camera mounted in grill **
My Mileage
Re: Two stupid questions... [Re: TacoYota] #563603 02/06/05 02:28 AM
Thanks!
Tacomas went to a vertical grill in 2001. I'm not sure if you would describe the prior models as horizontal or not. I liked the 1998-2000 grills better than the 2001-2004.
I don't know the answer to question #2.
Re: Two stupid questions... #563604 02/06/05 02:57 AM
TacoYota Offline OP
The reason I ask is I parked next to a Tacoma tonight where the grill had vertical bars. Mine ('04) are horizontal.
Pardon my stupidity, but what do you mean by;
I kind of agree that the older grills look pretty good, but being the owner of an '04 I could never admit that within listening range of my Tacoma... <img src="/forums/images/graemlins/lol.gif" alt="" />
The last thing I need is a truck with a complex, It's tough enough dealing with my girlfriend day to day... <img src="/forums/images/graemlins/zombie.gif" alt="" />
My Mileage
Re: Two stupid questions... [Re: TacoYota] #563605 02/06/05 04:45 AM
Here's a link to a picture of a 2000 Tacoma. Maybe the center bars of the grill are horizontal. I don't know if that's what you mean or not. I do like this grill better than the later Tacomas.
I have a 2003 with the 4cyl. It's butt ugly and I don't like the 2.7L as well as my old 3.0L engine. I know - I'm just too fussy. Humbug.
http://cgi.ebay.com/ebaymotors/ws/e...4524318639&rd=1#ebayphotohosting
Re: Two stupid questions... [Re: TacoYota] #563606 02/06/05 05:33 PM
atavuss Offline
Thanks!
don't know on your first question, but there is an easy mod to make your keyless entry function as an alarm, sans the glass breakage sensor (which you can get from toyota). do a search on this site and it should find the info for you.
04 4x4 Double Cab Tacoma v6 TRD, all stock
77 Jeep CJ7, 304 v8, 33x12.50x15 bfg, 4.10 gears, 44 rear end, ford bronco low range gear mod, warn 6k winch, rubicon tested
1969 M274a5 Military Mechanical Mule
46 Bantam Civilian trailer
Re: Two stupid questions... #563607 02/10/05 04:01 AM
drew96 Offline
I have a 96 with the 4cyl.
I would have to agree that the 2.7 is "fussy". In fact I've blown mine up twice, however I don't think the 3.0 is enough either so I'm looking to go with a small block chevy in the near future. Wish me luck, I've heard it can be challenging. <img src="/forums/images/graemlins/cheers.gif" alt="" />
96 taco 4x4 Fabtech adj coilovers in the front, BDS leafs in the rear, 32x12.50 MTRs, Downey Offroad header/Flowmaster, not bad for now, sas this winter
Re: Two stupid questions... [Re: drew96] #563608 02/10/05 04:08 AM
what are you doing to blow a 2.7 <img src="/forums/images/graemlins/confused.gif" alt="" />
twice for that matter <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: Two stupid questions... #563609 02/11/05 04:40 AM
kewlynx Offline
No kiddin'-- mebbee should stick to GM stuff; cheaper to replace! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
**ubi apis- ibi salus**
Re: Two stupid questions... [Re: kewlynx] #563610 02/25/05 01:58 AM
drew96 Offline
Suppose i'm driving to hard. The second time was because of a shady yet very expensive rebuild. Once i put the engine back in it lasted about 3000 mi before i blew a head gasket, when i replaced the gasket i found that the dohc timing gears were off 1 tooth, then i checked compression(you dont even want to know <img src="/forums/images/graemlins/scared.gif" alt="" />). So i got back somewhat right and a few weeks later i cracked the valve cover and it was <img src="/forums/images/graemlins/ignore.gif" alt="" />ed before the dummy light ever popped up. bad luck or stupidity? But anyway I'm game to anybody that knows of a 2.7 laying around because although id like to do a small block swap i really miss driving my toy.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6196 MB (Peak: 0.7232 MB) Data Comp: Off Server Time: 2026-06-18 11:16:02 UTC
