Page 2 of 3 1 2 3
Re: Oil filter tricks 5vze [Re: Mark in AZ] #564211 02/08/05 05:34 AM
Marc M Offline
What'd I say ??? <img src="/forums/images/graemlins/confused.gif" alt="" />
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5/TRD....
'90 4Runner 4X4 SR5 5-Spd
'86 Shortbed 4X4 5-Spd, SAS'd ASAP
'82 Supra 5-Spd
Take your automatic and "Stick" it........
My Web Album in Progress
Re: Oil filter tricks 5vze [Re: Mark in AZ] #564212 02/08/05 02:53 PM
I found that if you buy a 2005 Tacoma....
You need to be slapped really, really, hard <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
INDEED! <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Re: Oil filter tricks 5vze [Re: Marc M] #564213 02/09/05 02:36 AM
Mark in AZ Offline
Toyota Moderator
What'd I say ???
Hey, it's all meant in fun...
You're saying it's fixed on the 4 liter, but we're stuck with the 3.4 (that we otherwise luv) <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/cyclops.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
Exploring in a T4R Ltd V8
Re: Oil filter tricks 5vze [Re: Mark in AZ] #564214 02/09/05 03:57 AM
Marc M Offline
I know, I was just funnin' <img src="/forums/images/graemlins/smile.gif" alt="" />
I had an '03 with the 3.4, from 0 to 60,000 miles.
'82 Supra 5-Spd
Re: Oil filter tricks 5vze [Re: Marc M] #564215 02/09/05 05:26 AM
99TRD Offline
When I change my oil I drain the oil pan first and then take off the skidplate and put the bucket directly under the filter and unscrew it...works great. I used to have a huge mess when it would drip down onto the skidplate and leak everywhere. But maybe try that next time its only four bolts and it saves a ton of cleanup. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Oil filter tricks 5vze [Re: 99TRD] #564216 02/09/05 08:28 AM
4
4xGeek Offline
Relocation kit is pretty much your only hope... <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Oil filter tricks 5vze [Re: 99TRD] #564217 02/09/05 01:06 PM
Not sure how you do this? I remove both skid plates (9 or 10 bolts) and when I unscrew the filter it runs all over the side of the motor and the 4wd hardware, what a mess!
The relocation kit looks neat too. Who all primes the oil system before starting after a change? I typically pull the EFI fuse and turn the key until the oil light goes out, then put the fuse back in and start-r-up. It just pains me to hear the motor run and see the oil light still on!
Re: Oil filter tricks 5vze #564218 02/09/05 04:58 PM
Marc M Offline
I used to take a plastic grocery bag and slid it under the filter, pull the center down to a point and use a pair of scissors to make a cut, then remove the filter. Oil drains in bag, runs to slit in bag, then drains into drain pan. No mess
'82 Supra 5-Spd
Re: Oil filter tricks 5vze [Re: Marc M] #564219 02/09/05 08:52 PM
hairytaco Offline
this really works.......what a genius <img src="/forums/images/graemlins/kewl.gif" alt="" />
2008 Tacoma 4x4 6spd manual SR5 TRD
Re: Oil filter tricks 5vze #564220 02/10/05 12:00 AM
99TRD Offline
I've never had it drip down the block before, I mean it drips out of where you put the oil filter on but nothing to drastic since most of the oil falls right into the bucket...I usually only take off the bottom skid plate covering the oil pan and everything works fine
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6368 MB (Peak: 0.7451 MB) Data Comp: Off Server Time: 2026-06-17 16:37:26 UTC
