Oil filter tricks 5vze
#564201
02/07/05 12:38 AM
If you have any tricks for not making a mess when changing the oil filter on the v6 please let me know! I thought I had the secret today.. I sharpened a brass pipe, connected it to my pnumatic oil extractor and tried to jab it into the oil filter to suck out all the oil before I unscrewed it. Looked great on paper!! Unfortunately.... the Toyota filters are tuff and the rod wouldn't go through it. I ended up jabbing it with a screw driver and then sticking the oil extractor tube into that hole and it made 95% less mess than a normal filter swap, but I still had oil to clean up.... so what's the secret to do it with no mess??? On the plus side, I learned that the oil extractor works awesome! I sucked the oil out the dip stick hole, then pulled the drain plug to see how much was still in there. Not one single drop came out!! Here's the oil extractor, it works slick: http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=46149
Re: Oil filter tricks 5vze
#564202
02/07/05 03:04 AM
interesting idea wish i could figure out how to keep the mess down from when i pull the filter i just end up moving the bucket around trying to catch it all but still makes a hell of a mess
#564203
02/07/05 01:28 PM
How about make a small hole on the filter and use compresssor air to force all the oil toward the engine block, I will try that on the next oil change.
#564204
02/07/05 04:58 PM
Jiffylube <img src="/forums/images/graemlins/cheers.gif" alt="" />
2008 Tacoma 4x4 6spd manual SR5 TRD
[Re: hairytaco]
#564205
02/07/05 07:01 PM
Jiffylube <img src="/forums/images/graemlins/cheers.gif" alt="" /> Before you consider Jiffylube, check out the URL below and the WEB in general. You'll learn that Jiffylube has had more complaints than any other quick lube place. The damage their employees have done to vehicles is amazing. The stories at the sucks site clearly indicates they spend little time or $$$ training employees. http://www.jiffylubesucks.com/
Mike Murrell '95 Rodeo - 3.2 liter - 2WD - Automatic '04 Tacoma - 4 banger - Automatic
[Re: isuzu95]
#564206
02/07/05 07:17 PM
the site is down or something, but I know where you're coming from. Thanx for the info. <img src="/forums/images/graemlins/kewl.gif" alt="" />
#564207
02/07/05 09:16 PM
I have the same problem with the filter mess when I change oil in my 4 banger. The suction method of changing oil is a great way to do it. I use the Pela suction pump I noticed that I got more out than when I changed oil from below. When I changed oil in my wife's VW diesel, I can use the Pela to suck the oil out of the filter canister which opens from the top next to the engine. I wish more vehicles had this design. It is like the early 1950s chevy pickups
#564208
02/08/05 12:29 AM
man screw jiffylube
i took my truck there to have a full fluid change done and they <img src="/forums/images/graemlins/ignore.gif" alt="" />ED it up bad i knew i should have done it myself <img src="/forums/images/graemlins/angry.gif" alt="" /> they over filled the motor oil <img src="/forums/images/graemlins/scared.gif" alt="" />
under fill the tranny and spilled around a quart down the engine <img src="/forums/images/graemlins/scared.gif" alt="" />
they didn't remove the 2 skid plates to refill the front diff so they tried the fill it back up using the drain hole <img src="/forums/images/graemlins/zombie.gif" alt="" />
they almost rounded the rear diff fill plug, the only reason they didn't round it off is because i told them to stop and don't even try to take it off
they have a bunch of <img src="/forums/images/graemlins/butwiggle.gif" alt="" />holes working there that do not care so i am never taking my truck anyplace to have my fluids changed again
#564209
02/08/05 12:41 AM
I found that if you buy a 2005 Tacoma with the 4.0, it's alot easier to change the oil and filter.... <img src="/forums/images/graemlins/kewl.gif" alt="" />
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5/TRD.... '90 4Runner 4X4 SR5 5-Spd '86 Shortbed 4X4 5-Spd, SAS'd ASAP '82 Supra 5-Spd Take your automatic and "Stick" it........ My Web Album in Progress
[Re: Marc M]
#564210
02/08/05 03:10 AM
Toyota Moderator
I found that if you buy a 2005 Tacoma.... You need to be slapped really, really, hard <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Wheeling a Stepside Tacoma on 37s Exploring in a T4R Ltd V8
