Re: Oil filter tricks 5vze
[Re: Mark in AZ]
#564211
02/08/05 05:34 AM
What'd I say ??? <img src="/forums/images/graemlins/confused.gif" alt="" />
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5/TRD.... '90 4Runner 4X4 SR5 5-Spd '86 Shortbed 4X4 5-Spd, SAS'd ASAP '82 Supra 5-Spd Take your automatic and "Stick" it........ My Web Album in Progress
[Re: Mark in AZ]
#564212
02/08/05 02:53 PM
I found that if you buy a 2005 Tacoma.... You need to be slapped really, really, hard <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> INDEED! <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
[Re: Marc M]
#564213
02/09/05 02:36 AM
Toyota Moderator
Hey, it's all meant in fun... You're saying it's fixed on the 4 liter, but we're stuck with the 3.4 (that we otherwise luv) <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/cyclops.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
Wheeling a Stepside Tacoma on 37s Exploring in a T4R Ltd V8
[Re: Mark in AZ]
#564214
02/09/05 03:57 AM
I know, I was just funnin' <img src="/forums/images/graemlins/smile.gif" alt="" />
I had an '03 with the 3.4, from 0 to 60,000 miles.
[Re: Marc M]
#564215
02/09/05 05:26 AM
When I change my oil I drain the oil pan first and then take off the skidplate and put the bucket directly under the filter and unscrew it...works great. I used to have a huge mess when it would drip down onto the skidplate and leak everywhere. But maybe try that next time its only four bolts and it saves a ton of cleanup. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: 99TRD]
#564216
02/09/05 08:28 AM
Relocation kit is pretty much your only hope... <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris) '97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc... No longer stuck in SoCal!!
[Re: 99TRD]
#564217
02/09/05 01:06 PM
When I change my oil I drain the oil pan first and then take off the skidplate and put the bucket directly under the filter and unscrew it...works great. I used to have a huge mess when it would drip down onto the skidplate and leak everywhere. But maybe try that next time its only four bolts and it saves a ton of cleanup. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Not sure how you do this? I remove both skid plates (9 or 10 bolts) and when I unscrew the filter it runs all over the side of the motor and the 4wd hardware, what a mess! The relocation kit looks neat too. Who all primes the oil system before starting after a change? I typically pull the EFI fuse and turn the key until the oil light goes out, then put the fuse back in and start-r-up. It just pains me to hear the motor run and see the oil light still on!
#564218
02/09/05 04:58 PM
I used to take a plastic grocery bag and slid it under the filter, pull the center down to a point and use a pair of scissors to make a cut, then remove the filter. Oil drains in bag, runs to slit in bag, then drains into drain pan. No mess
[Re: Marc M]
#564219
02/09/05 08:52 PM
this really works.......what a genius <img src="/forums/images/graemlins/kewl.gif" alt="" />
2008 Tacoma 4x4 6spd manual SR5 TRD
#564220
02/10/05 12:00 AM
I've never had it drip down the block before, I mean it drips out of where you put the oil filter on but nothing to drastic since most of the oil falls right into the bucket...I usually only take off the bottom skid plate covering the oil pan and everything works fine
