Re: Some Enlightening Info About Brakes on Gen One's !
[Re: BobShaw]
#564488
02/12/05 08:52 PM
Bob, the combination of of art that is pre-existing to get a patent must be something that is not apparent / obvious to a layman.
AKA no patents for the obvious.
That says.. If bigger brakes came on an 89 its not considered an invention to put them on an 87.
Good point on prior art, since everything we do in one way or another is based on prior knowledge and existing designs.
Putting helical gears into a differential to produce a traction device is a good example of a combination of prior art being patentable (torsen diff).
Basicly I was going for... You cant get a valid patent for cylindrical device with a hole in the center rotating on a shaft used to reduce friction of a horse drawn sled. <img src="/forums/images/graemlins/smile.gif" alt="" />
I'm named on a few patents and have three more in process. I got one less then two weeks ago, I should have done a better job of explaining what I was trying to say.
Kevin
[Re: BobShaw]
#564489
02/12/05 09:05 PM
Bob, the bracket I am refering to is the black painted part in the second picture from bottom on the brakes web page. You can see me holding it in my hand. web page It is bolted to the spindle and holds the pads and the calipers. There is a similar bracket on the 87 brakes that holds the pads and caliper. Kevin
[Re: BobShaw]
#564490
02/12/05 09:06 PM
NAPA also sells calliper assemblies "loaded". That means rebuilt, includes new pads and hardware and is PREASSEMBLED. With the metal sleeves and rubber inserts and all?
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6026 MB (Peak: 0.6571 MB) Data Comp: Off Server Time: 2026-06-20 17:30:41 UTCValid HTML 5 and Valid CSS
