Page 2 of 3 1 2 3
Re: Considering SAS on my 98 Rodeo [Re: houlster] #566026 02/11/05 12:08 AM
kobyhud Offline
I don't think HP is that big of a deal. I haven't really had any problems with my front shaft, I will admit that offroad I just pull it into 2wd when I am going to exceed 10MPH though. It has been good about letting me know how fast is too fast.
My brother has the toy 80series e-locker center section in a mini truck front end. it only took about a day to do and turned out nicely. So he is High pinion and it is nice, but not THAT nice. The center section will run you over 900 bones. A mini truck axle about 200-250. high steer or crossover will be another couple hundred I just didnt like the width on this axle. All said and done I would budget about 1500 for a HP toy 80 series with electronics and stuff, or about 1200 or so to make a Dana44 work with nice steering and such. Its really sixes, because you have expenses both ways. Doing it again, I might have tried harder to find a 80 series axle with e-locker complete. Its a tough axle, only problem is gearing options. you pretty much got 4.10, 4.56 4.88 and 5.29. This is hard to mesh back into the Dana/GM world of 5.13 and 5.38. Although a 80 series can have upgraded birfs and inner shafts don't forget that the R&P doesn't get stronger at the same time. If you go toy, I say stick with lower ratios, not the 5.29s.
Well that is all I have to say for now.
Always take everything I say with a grain of salt. smile
95 Rodeo LS, Auto, SAS, , 60 front, 14 bolt rear. 5.13 r&p, Hydro-Assist, teras..
http://www.pieceofhud.com/gallery
Re: Considering SAS on my 98 Rodeo [Re: houlster] #566027 02/11/05 12:30 AM
A
AZPetrak Offline OP
Dan, thank you for the offer to help, I was hopping to be able to use your abundant knowlege. I will probably want to stop by and look at your axle and steering set up relatively soon. I did not look at your steering setup close enough when we did the Box Canyon/Coke Ovens run.
I would have never even considered a Toy axle if it wasn't for you. I always heard bad things about birfields, but the stronger one in the 80 axle sounds good. I also like the almost CV charactistics of birfields as opposed to ujoins contant acceleration - deceleration especially in slow crawling - high torq situations.
I know that the 80 series axle will be a little more expensive to buy, but all I should have to do is put in a locker(unless I am luck enough to find one stock) which should make it less expensive in the long run. I think the WMS to WMS is the same as the dana 44 rear in my Rodeo and it is HP and pass drop. I assume it is 6 on 5.5 like our Isuszus, I know most Toys are.
2007 4x4 Tacoma Dbl Cab with TDR and rear locker - stock for now
2001 Wrangler Sport - sold
1998 Rodeo S 4x4 - traded in
Re: Considering SAS on my 98 Rodeo [Re: AZPetrak] #566028 02/11/05 01:43 AM
randii Offline
Going with a high-pinion axle will help if you keep the short driveline used with your Isuzu t-case... it is less of a big deal if you use a different tranny/t-case combination that winds up being longer. The FJ80 axle looks pretty cheap when you factor in the cost of retubing a Dana... still better if you can find one with an E-locker and the gears you want to go to.
Sounds like you have some pretty good wrench and fab experience/tools, so that's a step in the right direction. As for taking Dan's help, JUMP on that -- he's a talented fabricator and makes a mean latte' as well, just exercise some caution with the wheeled chairs at the kitchen table next to the expensive art glass. <img src="/forums/images/graemlins/notooth.gif" alt="" />
I don't remember what the deal was with the steering pump, but I would actually expect it to work just fine with a normal steering box. The bets are off if you wanna run full hydro or assist, tho.
I agree with doing leaf springs to keep it simple -- they are WAY less complex than links and coils, though you do give up some flex. Pick your poison...
Randii
Re: Considering SAS on my 98 Rodeo [Re: randii] #566029 02/11/05 02:39 AM
Ride Hard Offline
I was thinking about using YJ springs, they are a little shorter than the Waggi 4044 which will give up a little flex, but will help in moving the axle forward and I can probably find about any reasonable spring rate I want. I am doing leaf springs to keep things as simple as possible.
Actually, those are the leafs I used... They are about 2-3 inches shorter than the wagoneer ones... At first I thought they might sag, maybe beacuase my rodeo might be heavier than a yj, But my wheel wells havent moved at all, in over 5 months... But who knows what can happen down the line <img src="/forums/images/graemlins/drunk.gif" alt="" />
'93 Rodeo - Dana 60 FF Rear - Dana 44 Front - 35's
Re: Considering SAS on my 98 Rodeo [Re: randii] #566030 02/11/05 04:24 AM
paulevans76 Offline
Randii
i dunno if you realy give up that much flex. it all depends on how much thought you put into it. you can put together a pretty dang flexy leaf setup, if you use the right combination. just wait till you see mine <img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
paul
88 Troop - Posing yard art
Re: Considering SAS on my 98 Rodeo [Re: kobyhud] #566031 02/11/05 05:00 AM
Starchild Offline
Just curious, is this typical of an SAS? I never considered the speed capabilities in 4wd. I know it all depends on the particular setup, but what is realistic?
"SERENITY NOW!"
Re: Considering SAS on my 98 Rodeo [Re: paulevans76] #566032 02/11/05 05:50 AM
randii Offline
I know that I could put together a pretty dang flexy leaf suspension -- BTDT. <img src="/forums/images/graemlins/pfft.gif" alt="" />
The first SAS build on Uzi flexed *well* beyond 1000 on a 23-degree ramp... but it had excess body roll and sagged out the front Toyota springs pretty fast, and wrapped the rear Chevy springs badly. I tuned the suspension a couple of times until I got it where I liked the balance of street handling, trail performance, and longevity. The result is less flexy but way more predictable.
Randii
Re: Considering SAS on my 98 Rodeo [Re: Starchild] #566033 02/11/05 09:26 AM
houlster Offline
Isuzu Moderator
No, not really. I've run it up to 65 or so with no problems just to see how it is. I start to get vibration about there from a less than perfectly balanced front driveshaft, but it's still pretty good for having lengthend it myself.
I think you would need some pretty steep driveline angles to worry about 4HI and SAS. Lots of things come into play that could effect it in a particular setup.
--Dan
Re: Considering SAS on my 98 Rodeo [Re: randii] #566034 02/11/05 05:06 PM
paulevans76 Offline
Randii
right on.
my plan is to use long-ish (48-53") packs, some arch--but not a lot, lots of leaves for progressivity, shackle at about a 50* angle on the shorter side of the spring, eyes parallel to the ground, and the best shocks I can afford. that combined with a low amt of lift and a wide stance ought to work pretty good all-around <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Considering SAS on my 98 Rodeo [Re: kobyhud] #566035 02/11/05 06:09 PM
A
AZPetrak Offline OP
I don't think a mini-truck axle will be wide enough for me. Ideally I would like an axle 1 - 2 inches wider than the rear. I would like to run a wheel with a lot of back spacing so I have as little tire scrub as possible when turning the front tires. This way I will have to worry less about stuffing 35" tires in the front wheel wells.
I didn't think about this/know this, I had originally thought about running 5.13 gears but I think 4.88:1 will work OK, it is just shy:
NewTire / OldTire x CurrentGear = New Gear
(34.8 / 28.9) x 4.1 = 4.937
So 4.88 should work, I would rather go on the high side but in this case do not have a choice.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6451 MB (Peak: 0.7585 MB) Data Comp: Off Server Time: 2026-07-15 09:02:39 UTC
