People who need 02 sensors #566136 02/10/05 01:04 AM
solarcrew Offline OP
<img src="/forums/images/graemlins/cheers.gif" alt="" />Since I've seen a lot of threads lately asking about 02 sensors i thought I'd post this.Sparkplugs.com has Denso OE identical 02 sensors for $37.75+ $7.98 shipping.The part#234-1051.This is for the 22re.They also have other styles for different motors at low prices.Hope this helps you folks out! <img src="/forums/images/graemlins/kewl.gif" alt="" />
87'4runner-22re,5spd
Re: People who need 02 sensors [Re: solarcrew] #566137 02/10/05 04:44 AM
4Crawler Offline
That's where I got mine last year. Fit fine and seems to work well.
Re: People who need 02 sensors [Re: solarcrew] #566138 02/10/05 09:20 AM
Buster Offline
Bought one there last month for my '86 and will probably buy another for my '85 shortly. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: People who need 02 sensors [Re: Buster] #566139 02/10/05 12:36 PM
Kletzenklueffer Offline
What is the indication that you need a new one?
Re: People who need 02 sensors [Re: Kletzenklueffer] #566140 02/10/05 05:46 PM
guill Offline
Your check engine light
I don'T remenber witch code...
Guill
88 4Runner 22RE 4x4
Montreal Canada
www.hexcostainless.com/images/fart.gif
Re: People who need 02 sensors [Re: guill] #566141 02/10/05 09:56 PM
<img src="/forums/images/graemlins/kewl.gif" alt="" />I have an air/fuel gauge which shows that the 02 sensor is sending a good reading to the ecu.It has indicator lights that should constantly flash up and down the scale of the gauge to show the ecu is constantly looking for the right fuel mixture.Right now the 02 works when the cold start high idle is running.But it seems to stop working after warmup.I just get a constant set of lites towards the lean side of the gauge with no flashing.I'm not sure if this is open or closed loop on the ecu.Maybe someone a little more knowledgable will chime in about that. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: People who need 02 sensors [Re: 4Crawler] #566142 02/11/05 05:27 AM
9
92daily Offline
I notice that the sensors are marked front and back. I only have one and it's infront of the cat. I beleive my truck is technically the dlx model (must not stand for deluxe cause I've got no power options). So which one would I need? <img src="/forums/images/graemlins/confused.gif" alt="" />
I'm between toyotas right now... 3rd Gen 4-runner soon.
Re: People who need 02 sensors [Re: 92daily] #566143 02/11/05 09:07 PM
<img src="/forums/images/graemlins/cheers.gif" alt="" />If you've got a 22re,then the same 02 sensor will work on your truck.I also only have 1,it's just below the exhaust manifold.It's a single wire sensor. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6210 MB (Peak: 0.7032 MB) Data Comp: Off Server Time: 2026-11-02 03:07:56 UTC
