What is a good price for this 4runner -
#567861
02/13/05 11:01 PM
found an 84 4runner 4x4 202k - everything is stock straigh no rust looks like it was just used as a daliy driver, no scaring at all underneth from wheeling. Drives good most everything seem to work with the exceptoin of heat & possible rear window. The motor leaks and burns a little but starts right up idles fine and sounds good - no knock or taps and absolutly no power, so it's tired! The trans 4 hi and lo all work. The interior has the altimeter set-up power windows and factory sun roof. It's real real dirty but I didn't see any cracks in the dash. It has no ac. So that is the basic rundown - the truck looks like a 20 year old truck that was used and and not kept perfectly maintained. Oh Paint is original but faded. Clear title - didn't feel any bondo. The question - what is this truck worth?
Thanks, TBob
TBob All but SAC'ed! Had God not driven man from the Garden of Eden, the Sierra Club would have. P.S. Greenies SUCK!
Re: What is a good price for this 4runner -
[Re: AZTBob]
#567862
02/13/05 11:14 PM
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
[Re: kyle-22r]
#567863
02/14/05 04:39 AM
yah, probably not more than 2 grand. if the frame and body are good it may be worth it. You can replace the motor much easier than the frame/body. check to see how loose the front and rear differentials are, and if they are leaking any oil. once again these can be replaced easily. But if eveything seems pretty beat, you should be able to get the price under $1500 no problem.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod. -'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
