95 YJ Weird idle? #568898 02/15/05 07:19 PM
injected 4cyl, the idle runs fine until the engine warms up, then there is intermittent power loss and the idle drops down to a near stall... just had a tune and cleaning, but that didnt fix it (runs better, though)
The co2 sensor is new, anyne have any ideas?
Thanks!
Re: 95 YJ Weird idle? #568899 02/15/05 11:00 PM
BoggerCJ7 Offline
You're definately describing what sounds to be a bad O2 sensor. When the Jeep is warming up to optimal running temperature, it is in closed-loop operation (not using the O2 sensor). When the engine gets to operating temp, it then relies on the O2 sensor for readings of cumbusted exhasut; which in turn adjusts the engine's air/fuel mixutre.
If the O2 sensor is new, I would have a scanner hooked up to it that can test its operation. There is a power-ground lead to the O2 sensor from the ECM and it might not be getting a signal.
I would also check the IAC (idle air control) and the TPS (throttle position sensor) sensors. They can cause a rough idle as well. Pop off your intake tube and look into your throttle body. Sometimes a good cleaning with some carb spray does wonders.
Chris
1983 CJ7 with 1.21 giga-watts and a supercharged flux-capacitor
PHP: 7.4.33 Page Time: 0.010s Queries: 14 (0.008s) Memory: 0.5842 MB (Peak: 0.6317 MB) Data Comp: Off Server Time: 2026-11-05 15:17:56 UTC
