4Runner ARB in a supra MKIII housing? #568942 02/15/05 08:08 PM
4
4runner4ever Offline OP
A question for all ya gear gurus.
Is it possible to mount an V6 ARB in a supra MKIII housing?
A friend is into supraÆs and he wants to build a MKIII supra with 2JZ-GTE engine for drifting. The car has to be driven to and from the circuit so the locker needs to be selectable. The desired gear ratio is 3.3 but 3.54 will do also. I allready found that the 3.54 ratio is available in normal 8ö version.
In my experience I found that:
a) the 8ö V6 gears can be replaced with 8ö gears when shimmed out properly
b) the supra (86-95) uses 8ö V6 gears
c) the supra LSD fits the V6 housing
d) the ARB is available in V6 model, but normal 8ö model fits also when V6 gears are used
He first wanted to replace the rear axle of this supra with a Hilux solid axle, OEM locker , 2WD axle stubs (5 bolt) and MKIII rear discs and MKII rear parking brake drums.
I allready built this axle (except for the locker) but now he wants to use this for a customer with a new project and maintain the supra rear suspension and just fit an ARB.
So, is it possible to use an ARB in an supra MKIII housing?
If the supra LSD fits the V6 4Runner the axlestubs should have the exact same splines, right?
P.S.: I don't want to start a debat about safety or things braking apart. It's only going to be raced on circuit and we have lots of spare parts. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Black '90 4R
SAS with LC80 coils and LC70 high pinion axle
LC80 rear axle, coils and locker
4.88 gears
2JZ-GE+turbo+intercooler
Re: 4Runner ARB in a supra MKIII housing? [Re: 4runner4ever] #568943 02/16/05 03:35 AM
larsdennert Offline
An RD23 should fit fine.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5854 MB (Peak: 0.6344 MB) Data Comp: Off Server Time: 2026-11-16 08:48:45 UTC
