bottom part of new radiator #569033 02/16/05 02:06 AM
anthony1 Offline OP
I bought a replacement 3 row radiator a few yrs ago. It had another in/out port on the bottom which I assume is for the auto trans oil. I have stick.
I have this idea of using the bottom ports for heat exchange for how shower...all I need is a water pump, hoses, hot/cold mix. What do you all think?
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: bottom part of new radiator [Re: anthony1] #569034 02/16/05 02:24 AM
OOP'S Offline
It will sort of work, there are not enough coils in there to get the water hot enough. Had a friend try it with mixed results!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: bottom part of new radiator [Re: anthony1] #569035 02/16/05 02:27 AM
sounds like a good idea but man that would be some hot water
wouldn't the water that comes threw the tranny cooler have the same amount of heat as the engine coolent
Re: bottom part of new radiator #569036 02/16/05 02:40 AM
OOP'S Offline
I have an on-board shower on my rig that I bought, it is mounted in line with the heater hoses and you regulate the heat from the shower with the heater controls and the RPM's of the engine.
David Fritzsche
Roseville, CA
Re: bottom part of new radiator #569037 02/16/05 06:25 PM
anthony1 Offline OP
Hmmmm, I confused now...will the water be too hot or not hot enough?...the water will go through the radiator. it doesn't mix with it. It doesn't go through the transmission cooler at all...the only place the water path comes in contact is the radiator. Maybe it has to do with the water flow rate.
Re: bottom part of new radiator [Re: anthony1] #569038 02/16/05 07:05 PM
4Crawler Offline
I've never heard a definitive answer to the water temps, I've heard both too hot and not hot enough. Never seen a shower using that for a heat source personally. I suppose one option is to plumb it up and see how it works. The A/T cooler is just a loop or two of hard line inside the lower radiator tank connected to the two external fittings. I tend to agree with Oops that there is not enough surface area to heat the water up enough in one pass. The R&M exchanger I have (same as Ooops has) uses three small copper tubes coiled up inside the bigger tube that coolant flows through. Never opened mine up but there is probably 10 ft. of tubing inside which gives a lot of surface area for maximum heat transfer. If the temp rise is not enough in one pass, I suppose you could rig up a bucket and cycle the bucket water through the rad. until it is hot then switch over to pump it through the shower head.
Re: bottom part of new radiator [Re: 4Crawler] #569039 02/16/05 07:39 PM
Robinhood150 Offline
I've never heard a definitive answer to the water temps, I've heard both too hot and not hot enough. Never seen a shower using that for a heat source personally. I suppose one option is to plumb it up and see how it works. ...
... I tend to agree with Oops that there is not enough surface area to heat the water up enough in one pass...
Ditto
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: bottom part of new radiator [Re: Robinhood150] #569040 02/16/05 09:20 PM
mt_goat Offline
I have used a thermocouple on my multimeter and tested the temp drop of my ATF going through the radiator cooler and found only a 5 deg drop from the line in to the line out. Not a great heat exchanger. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6224 MB (Peak: 0.7176 MB) Data Comp: Off Server Time: 2026-07-17 00:01:32 UTC
