Page 3 of 6 1 2 3 4 5 6
Re: Let's talk about the idea of a new isuzu gear ratio [Re: paulevans76] #569912 02/18/05 12:19 AM
muskyamigo Offline
I looked into a set of 5.38 for my 98 with the V6. They would be great around town and on the trail. But 1/2 my daily commute is on a freeway with a 70mph speed limit. If the roads are dry, 70 is SLOW. With 5.38's the engine would be spinning way too fast on the freeway.
5.13's would be ideal for my case. The 4.88's would be great too.
I would certainly be interested (front only)!
If I'm not mistaken, aren't 4.88's available for the 3.xx D44 carrier? I believe because of the Rubicon?
Mike W
Re: Let's talk about the idea of a new isuzu gear ratio [Re: matthew] #569913 02/18/05 12:35 AM
randii Offline
i guess the 4.77 mythology would disapear <img src="/forums/images/graemlins/lol.gif" alt="" />
I would buy a set just to help put a silver bullet through all the discussions about those 4.77s.
Besides, these mythical gears are cutting into the unique mystique of Uzi! <img src="/forums/images/graemlins/pfft.gif" alt="" />
Randii
Re: Let's talk about the idea of a new isuzu gear ratio [Re: muskyamigo] #569914 02/18/05 12:39 AM
matthew Offline OP
you got it <img src="/forums/images/graemlins/smile.gif" alt="" />
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: Let's talk about the idea of a new isuzu gear ratio [Re: matthew] #569915 02/18/05 12:40 AM
Ahhh. now we got the wheels in your head turning. I Would also prefer 4.88's over the 4.77's. The only reason I am after 4.77's is that 5.38's would be too low for my 33's. I wouldn't mind paying 4bengis for a set-o-4.88's. I am thinking about putting a Ford 8.8 in the rear. Does anyone know if the 4.88's are avalible for that axle? The only reason I am going with a 8.8 is the free factor. But then I will still have to adapt disk brakes to it. Hummm I guess I just need a really cheap D44 from one of you Rodeo guys that swapped in a bigger axle.
Re: Let's talk about the idea of a new isuzu gear ratio [Re: paulevans76] #569916 02/18/05 12:42 AM
matthew Offline OP
good idea, 4.88 matches up to dana and toyota stuff,
exactly..........what do you guys think i do all day besides sit around and try to fill in the pieces of the puzzle <img src="/forums/images/graemlins/lol.gif" alt="" />
fielded a couple calls just today for PNW guys looking for Toy "matching" gears for axle swaps.
OH CRAP....i can see it now.............all the Toyota rear to Isuzu 12 bolt swaps w/ 4.88's and a Lockright <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
i already have jeepers doing rear Rodeo D44 swaps.
Re: Let's talk about the idea of a new isuzu gear ratio [Re: randii] #569917 02/18/05 01:02 AM
N
Nazrat Offline
Anyone want to buy a set of 4.77 3rd members with ARB lockers installed? I'd better sell while the lure of 4.88s has everyone all pumped up. (Calm down Smiley, I'm not selling... yet)
Personally I'd choose 4.88. I've run 4.77 with 31s, 285s, 33s, and now 34s and they work well. I have the older 3.2 DOHC so someone with a 3.5 or newer 3.2 DOHC should have even better results.
-Tad
1994 Trooper. 3.2 DOHC/auto. 4.77s,3xARB, OME 919HD springs. 34" Swamper LTBs
2001 Trooper "stock" <img src="/forums/images/graemlins/wink.gif" alt="" />
http://www.planetisuzoo.com
Re: Let's talk about the idea of a new isuzu gear ratio [Re: matthew] #569918 02/18/05 01:03 AM
CPOM Offline
I would buy a 4.88 or 5.13 ring and pinion set for a 12 bolt axle.
CHRIS
98 Amigo, 92 Pup
Re: Let's talk about the idea of a new isuzu gear ratio [Re: Nazrat] #569919 02/18/05 01:05 AM
barak Offline
Ok , I didn 't realize you could keep the LSD and just change the ratio.Sounds good , count me in.
Re: Let's talk about the idea of a new isuzu gear ratio [Re: Sfinx] #569920 02/18/05 02:45 PM
DieselBob Offline
Sfinx
Left out in the cold again <img src="/forums/images/graemlins/frown.gif" alt="" /> I feel your pain
Bob
"You can't expect to wield supreme executive power just 'cause some watery tart threw a sword at you."
02 Trooper S, TOD, Aisin Hubs, FJORD Blue, ARB 3444070 Winch Bar. Dueler A/T REVO LT265/75R16
Re: Let's talk about the idea of a new isuzu gear ratio [Re: barak] #569921 02/18/05 02:47 PM
Madcat Offline
I'd be in for a set of gears...but only after the powertax deal bears fruit.....or lockers <img src="/forums/images/graemlins/smile.gif" alt="" />
Madcat <img src="/forums/images/graemlins/kewl.gif" alt="" />
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6413 MB (Peak: 0.7499 MB) Data Comp: Off Server Time: 2026-06-09 10:13:35 UTC
