rear vibration
#569986
02/17/05 09:17 PM
ok i have a bad u joint and my transfercase flange and my pinion flange are a little loose. torque to transfer case nut is 90 and does anyone know how to tighten up the rear pinion (Stock 3rd). all the vibration goes away when the rear driveshaft is pulled
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
Re: rear vibration
[Re: willzrunna96]
#569987
02/17/05 09:46 PM
You can usually tighten the pinion the same as the t-case. Unstake the nut, tighten to take up any slack. I use a torque wrench set to click at 90 ft.lbs. on mine. You don't want to go too tight or you can cause the crush sleeve to crush some more. If that does not help, then you likely have a worn pinion bearing.
Re: rear vibration
[Re: 4Crawler]
#569988
02/18/05 02:32 AM
ALRIGHT I did my u-joints and torque my transfer case and then guess what i noticed. I must have been really drunk when i put my tranny. i was 90 degrees off. my driveshaft wasnt even close to phasing. i fixed it and now it feels like im driving a cadillac!! just thought i should tell you guys what was wrong since no one else has a final writeup of what was wrong.
Re: rear vibration
[Re: willzrunna96]
#569989
02/18/05 03:21 AM
Leave da beer on ice grasshoppa-- it's much colder when you are done, and still have all your fingas to wrap around to indulge. <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/shame.gif" alt="" />
Re: rear vibration
[Re: willzrunna96]
#569990
02/18/05 08:01 AM
I was going to suggest you check the drive shaft phase then read the rest of the thread and wahlah there you go.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6063 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-06-11 12:56:42 UTCValid HTML 5 and Valid CSS
