Re: added tundra seats to T100 today(pic) [Re: mmiller] #570865 02/21/05 01:26 AM
surlynkid Offline
looks nicer than my 97-97 cloth bucket i got from teh junkyard.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Ramsey Winch w/ TJM [Re: Creeper] #570866 02/21/05 04:33 AM
Honger Offline
mmiller:
Very nice seats and truck as a whole. I'm glad Creeper pointed out your website to us.
This is a bit of a hijack...
Just out of curiousity, what did you do to your TJM to be able to use the winch with it?
1998 Toyota T100 SR5 ExtraCab 4WD
Re: added tundra seats to T100 today(pic) [Re: surlynkid] #570867 02/21/05 04:05 PM
95T100 Offline
MMiller -
As you could probably sell us all the instructions to make the mods.... were the modifications simply drilling new holes or cutting off old metal or did you have to weld/fabricate anything. Judging by your rear bumper pictures you are obviously pretty handy with a welder.
Re: added tundra seats to T100 today(pic) [Re: 95T100] #570868 02/21/05 11:07 PM
uzombie Offline
Think you could take some pictures CLOSE UP of the mount points? And if you did anything underneath? (tack any nuts or clearance issues...)
Looks good! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: added tundra seats to T100 today(pic) [Re: Creeper] #570869 02/22/05 02:38 PM
mmiller Offline OP
Bkg-they are power seats. I was thinking residential wiring when I hooked them up (green-ground, black-hot) so the controls are backwards, but thats an easy fix.
Creeper-thanks for the compliments. I didn't ask about the motor. I have called back about the console, but they don't have it. I'm a bit of a Pontiac nut too, and have this 350hp 400 c.i. from an early Trans am sitting around. Hmmmm... Creeper, I'll be out in Wyoming this summer in my T and pop-up camper (camper has 4 inch lift and oversize tires).
Joel-When I put on my 3" body lift, I raised the TJM two inches. At that time I beefed up the brackets where they attache to the frame. I did try to get the winch brackets from the guy at TJM, but they never came despite his promise. Since the winch mounts so far above the frame, is the weak point higher up in the bumper? I think my frame mounts are ok. I would like to put some bracing higher up though since it looks kinda flimsy. So far I have only had to use it to pull some 700 lbs rocks around the yard.
95T100-uzombie-I'll work on a write up with some diagrams this week. I used all the existing front holes and one rear hole. I had to drill three new rear holes. The holes on the front brackets on the Tundra seats are a couple of inches too wide, so I cut of the brackets from the rails, added a tranverse bar between the rails and welded the feet back on the seat an inch or two inside of their original locations so they line up with the T100 bolt holes.
1997 T100 4x4 SR5 5spd
Re: added tundra seats to T100 today(pic) [Re: mmiller] #570870 02/22/05 05:36 PM
Creeper Offline
If you're heading up to Wapiti, keep me in mind. Maybe we could hook up for a day run or something. Is your brother moving back yet? Mountain biking should be good this summer but the snow has been pretty light this winter so the water will probably be low for fishing or rafting....
'97 T100 SR5 XCab 4WD
TRD SC ~ ARB ~ FWC
'85 FJ60 Landcruiser
4E9 ~ locked ~ 33's
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6197 MB (Peak: 0.6913 MB) Data Comp: Off Server Time: 2026-05-29 22:28:44 UTC
