2" BL installed - shifter problems... #570951 02/20/05 03:08 AM
A
AZTBob Offline OP
got it installed and my truck wouldn't shift. The lever was hitting the
metal bracket that goes around the rubber boot. The bracket could be modifed but I think I would have to hack out the whole center section and the rubber boot I think would still feel like it's beeing stretched - because it is, it's 2" higher and the lever throw is further than what it was. So what should I do to fix this? Any ideas?
Thanks
TBob
TBob
All but SAC'ed!
Had God not driven man from the Garden of Eden, the Sierra Club would have.
P.S. Greenies SUCK!
Re: 2" BL installed - shifter problems... [Re: AZTBob] #570952 02/20/05 06:30 PM
from what i have heard the shifter lever might need to be extended
you know cut the lever and add a peice in
Re: 2" BL installed - shifter problems... #570953 02/21/05 05:16 PM
CraShYota Offline
spend 50 bucks and get a short throw shifter...
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: 2" BL installed - shifter problems... [Re: CraShYota] #570954 02/21/05 08:33 PM
YOTA88 Offline
what X said. i had the same problem with mine. i cut out the center section of the metal bracket like you mentioned and it did allow the shifter into position but it streched the boot so much that i kept tearing them. once i extended the shifters it all went away.
SAS88TOY, caged, lockered, Longfielded, etc. etc. etc. blah blah blah!!!
2005 Tundra Quadcab.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5950 MB (Peak: 0.6523 MB) Data Comp: Off Server Time: 2026-06-21 12:15:49 UTC
