Page 10 of 15 1 2 8 9 10 11 12 14 15
Re: My next build up... (alot of pictures) [Re: Bigpoppax2] #571400 04/19/05 02:49 AM
onebadtrooper Offline
Well I don't have the 2.8 so I can't help on the harness, I know my plug to the gauges isn't blue.
Looks as if you are making some good progress.
Thats the plug before it gets to the gauges, Theres a smaller plug at the guages. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: My next build up... (alot of pictures) [Re: onebadtrooper] #571401 04/19/05 02:59 AM
what size tires are you gonna run, it'll be a shame to have to trim those nice new flares
Re: My next build up... (alot of pictures) #571402 04/19/05 03:15 AM
Daniel_T Offline OP
32 inch Thornbird. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
I am going to trim the fender and hope the flair stays the same. Rember these flairs already clear 35 inch tires with the IFS.
Later,
Daniel
"Thanks for the joy that you gave to me"
Re: My next build up... (alot of pictures) [Re: Daniel_T] #571403 04/19/05 03:58 AM
strawmyers Offline
Isuzu Moderator
32 inch Thornbird.
Please tell me someone is paying you to take these <img src="/forums/images/graemlins/lol.gif" alt="" />
Sean Strawmyer
Re: My next build up... (alot of pictures) [Re: strawmyers] #571404 04/19/05 04:07 AM
paulevans76 Offline
i believe that was a joke lolll <img src="/forums/images/graemlins/notooth.gif" alt="" />
those springs are sweet man. let me know when the fun starts and I'll bring the peanut gallery to help out <img src="/forums/images/graemlins/wink.gif" alt="" />
88 Troop - Posing yard art
Re: My next build up... (alot of pictures) [Re: Eric Upchurch] #571405 04/19/05 08:47 AM
Bansil Offline
I am going to go with a rev. manualy valve body. Should I spend the extra money and get one with a trans brake? Not sure if it would be of any use to me I am going to run line locks front and rear.
You might want to rethink this.
A rev. man. valve body is great in a street car,but in a truck it could be bad.........ie:
Normal shift is P R N 3 2 1
Rev body is P R N 1 2 3
If you need to get it into R quickly,it could be a
pain.
A trans brake will actual apply fliud pressure to REVERSE and 1 st gear at the same time (when truck is running). When released it can
shock alot of parts downhill in the drive train.
It will not hold you truck when it is turned off and park it.This is referenced to the part about line locks front and rear.
A manual valve body is neat/cool but when you stop,you have to physically put it into 1st gear and shift as you start to move.If you forget and leave it in say 3rd gear,when you pull away from the light you'll be trying to pullout in 3rd gear not 1st gear.
I would go with a "shift kit" and set it (drill holes etc)
so it is street/strip.This will give you full automatic shifting if your in 3rd(on indicator).
It will stay in 1st as long as shifter stays in first.
It will shift into 2nd and stay there as long as the shifter is in 2nd etc.
Linelocks are a very good thing <img src="/forums/images/graemlins/kewl.gif" alt="" /> make sure that you wire them up so they can have 12v. when the key is off....
for extended trail stops.........and then you can "turn them off" ....let's say when it's parked on level ground(so your battery won't die).
When you get it rebuilt ask the person rebuilding it about leaving the govenor spring and the servo spring out....it will speed up shifts and let the clutches slip less....
at least it did back in "the ol'school days" <img src="/forums/images/graemlins/smile.gif" alt="" />
Sorry so long hope this helps some.
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: My next build up... (alot of pictures) [Re: Bansil] #571406 04/19/05 05:10 PM
Daniel_T Offline OP
pain.
Bansil
That is the reason I want to go reverse manual. Then I can go from 1st to reverse alot faster. I know I will have to shift at all times now that is anouther thing I like about it. I just don't have to mess with the clucth pedal nomore;)
Later,
Daniel
Re: My next build up... (alot of pictures) [Re: Daniel_T] #571407 04/20/05 01:53 AM
Daniel_T Offline OP
Test fitted the motor tonight.
[Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image]
Here it how it looks from the side you kcan see the oil pan and the leaf spring hope that is going to work.
It is going to be tight I am more than likely going to have to use an electric water pump and a fan on the rad.
From where it sits now if anything I might have to move the motor forward an inch or so.
Here is the new 35 spline 4340 ALLOY STUB SHAFTS. Thanks Doug smile
Later,
Daniel
Re: My next build up... (alot of pictures) [Re: Eric Upchurch] #571408 04/20/05 08:43 AM
Bansil Offline
pain.
Bansil
Ooops,I guess that is quicker <img src="/forums/images/graemlins/ignore.gif" alt="" />......late nite <img src="/forums/images/graemlins/pfft.gif" alt="" />
Bansil
By the way nice shafts <img src="/forums/images/graemlins/kewl.gif" alt="" />
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: My next build up... (alot of pictures) [Re: Bansil] #571409 04/26/05 01:32 AM
Daniel_T Offline OP
Good news I finialy got my doubler in!!! <img src="/forums/images/graemlins/mrt.gif" alt="" /> I will take some pictures and post them for you tomorow. (have to get some batterys) Also have the new yokes in from Jess.
Later,
Daniel
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6553 MB (Peak: 0.7680 MB) Data Comp: Off Server Time: 2026-06-07 04:36:13 UTC
