Re: Auto hubs & trans [Re: JLEMOND] #571618 02/21/05 11:10 PM
COTrooper Offline
I don't mean to be insensitive and don't wish to sound as such... but, I have a brother-in-law who is leagally blind and finds it tremendously helpful to change the screen resolution so that the words are bigger. Further, if you're using a Windows mchine, there are special featuers you can employ to make the text bigger. Send me a private message if you'd like more information about this...
'98 Rodeo, Ranchos, OME 912s, General Grabber AT2 265/70/16s on steelies, Superwinch hubs, G80 code, Pioneer HU... two car seats and cracker crumbs.
Illegitimus non carborundum.
Educatio est omnium efficacissima forma rebellionis.
Re: Auto hubs & trans [Re: JLEMOND] #571619 02/22/05 12:43 AM
rheteric Offline
No need to be sorry for something you have no control over. I was just sorta alluding to the value you add to the board.... indirectly I suppose. That and curious as to why you seemed to be getting preferential treatment. Some day, some day <img src="/forums/images/graemlins/sleeping.gif" alt="" />
Now back to our regularly scheduled program....
www.burnlounge.com/mp3me
'00 Rodeo LS 4x4; "K&N" cone filter; S/S Manik Front, Rear, & Nerf; 'Modest' sound system; 1.5" R'ooper lift, 265/70/16 Dunlop RVxt, Skyjacker Hydros, OEM LSD (sans G80 code)
Re: Auto hubs & trans [Re: COTrooper] #571620 02/22/05 04:26 AM
taro Offline
I'm curious about the comment about being able to drive around with the manual hubs locked for extended periods of time. If this were the case, why the need for the shift-on-the-fly mechanism that connects/disconnects the driver's side wheel to the half shaft? I've kind of guessed that the front diff is not up to dealing with the stress of having to put up with the two front wheels traveling at different speeds like the rear does given that the front diff is a smaller unit, but...any thoughts? Thanks, Taro
Re: Auto hubs & trans [Re: taro] #571621 02/22/05 01:49 PM
RSimister Offline OP
This is a first gen Trooper with no shift on fly.When the hubs are locked both front axles,ring,pinion and drive shaft all spin and on the street it really sucks back the gas.My biggest concern now is if I put auto hubs on and JLEMOND is correct and they get ripped up then I'm further behind than before.Maybe this is something better left alone.
Re: Auto hubs & trans [Re: RSimister] #571622 02/22/05 03:35 PM
Chris Perosi Offline
Isuzu Staffer Emeritus
Jerry is correct (and by the way, that's not usually an "if"...) but if I understand correctly, that would mean that the auto hubs would work as they should work. In other words, you have to be stopped when you make the shift, you can't shift while moving. That's easy enough, as long as you make that clear to your wife... <img src="/forums/images/graemlins/wink.gif" alt="" />
It's more an issue of not wanting to turn all those parts at all times. The CV's will turn all the time, which could lead to premature CV boot (or even joint) failure. This is even more of an issue with a lift, where you're turning those boots with a high angle on them AT SPEED, which is something you don't really want to do. They're much more likely to tear. The SOTF is a better setup in this regard.
HTH,
Chris
Chris Perosi
Isuzu Editor Emeritus
OutdoorWire, Inc.
Re: Auto hubs & trans [Re: Chris Perosi] #571623 02/22/05 04:05 PM
BigSwede Offline
My old 88 Pathfinder was not SOTF. You had to stop to shift into 4WD to lock the hubs. Once the hubs were locked though, you could shift in and out of 4WD on the fly...you just had to keep track if you backed up, because the hubs would unlock then. No big deal.
Serenity now!
Re: Auto hubs & trans [Re: Chris Perosi] #571624 02/23/05 04:54 AM
taro Offline
so it sounds like running with the hubs locked on a non-sotf system is not a big deal. in that case, i'm not understanding the need for the sotf disconnect. if i'm understanding correctly, the disconnect is between the cv joint and the differential. therefore, i'm assuming the that the hub and the cv joint on the drivers side are always turning and that this is also true on the passenger side. it would seem that the sotf disconnect would not be preventing any wear on the cv joints. help<img src="/forums/images/graemlins/notooth.gif" alt="" />. thanks, taro
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6245 MB (Peak: 0.7198 MB) Data Comp: Off Server Time: 2026-06-20 16:38:35 UTC
