Rating: 3
Page 2 of 7 1 2 3 4 5 6 7
Re: ELECTRIC FAN - INSTALLATION [Re: fokion] #574690 09/03/07 08:48 PM
fokion Offline OP
and something needs to be done in order to be notified in case the fan does not spin...
Otherwise you end-up with an exploded rad....
Re: ELECTRIC FAN - INSTALLATION [Re: fokion] #574691 09/05/07 03:25 AM
Calappoyas Offline
A volt meter on the wire grounding the fan motor?
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils
http://www.cardomain.com/id/calapooyas
My beater, 03 Land Rover Freelander SE3
Re: ELECTRIC FAN - INSTALLATION [Re: Calappoyas] #574692 09/09/07 08:11 PM
fokion Offline OP
You need to know that you have "flow" of current at the fan..
Re: ELECTRIC FAN - INSTALLATION [Re: fokion] #574693 09/09/07 10:54 PM
bombardj1 Offline
how about a led light drilled and put in on one of the acc. blanks on both sides of the steering column, heck put in a buzzer of some sort. ???????? for you lighting bugs out there can the eletric fan be 2 speed automaticly depending on the temp ?
Re: ELECTRIC FAN - INSTALLATION [Re: bombardj1] #574694 09/10/07 12:22 AM
Everet Offline
Buy a SPAL FAN-PWM. You can program it to run fan @ 50% until it hit the next setting, then it will kick up to 100%. Also, when your AC is on, it will turn on your fan.
They are about $75 dollars on ebay.
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: ELECTRIC FAN - INSTALLATION [Re: Everet] #574695 09/14/07 08:07 PM
fokion Offline OP
@ everet... that does not save you from a... say burned fuse.....
I am tending to a buzzer.... but still that sounds when the "effect" is happening, not the..."reason"
Re: ELECTRIC FAN - INSTALLATION [Re: fokion] #574696 09/14/07 08:56 PM
A
Airdale73013 Offline
Look at the Tempature Guage.
2009 Sorento LX, 4x4, V6, Auto, Red
Re: ELECTRIC FAN - INSTALLATION [Re: Airdale73013] #574697 09/22/07 07:44 PM
fokion Offline OP
Yep you are right.....
But had a conversation with wife and was stuck to traffik and everything happened sooooo fast...
Re: ELECTRIC FAN - INSTALLATION [Re: fokion] #574698 06/04/08 07:51 PM
Nukeiridium Offline
the Spal PWM fan thing is great! I had one on my old sportage, I'm gonna put it on the new one too when I get around to it. Great piece of kit, when my old sportage got totalled I went to the junk yard and pulled off my stereo and my SPAL fan controller along with its wire harness I made smile
Too bad the fan itself was ruined, crushed <img src="/forums/images/graemlins/frown.gif" alt="" />
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: ELECTRIC FAN - INSTALLATION [Re: Nukeiridium] #574699 04/26/09 04:24 AM
ChrisB Offline
Do you guys let this fan spin the whole time the car is running?
01 Kia sportage,Removed front bumper,Warn manual hubs,
Soon To Come.Cb,4"lift,31's,Custom front bumper,Rock sliders,Winch,Roof rack,Hitch
Make it Break it
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6390 MB (Peak: 0.7469 MB) Data Comp: Off Server Time: 2026-10-21 14:32:36 UTC
