limited slip #574995 03/02/05 01:51 AM
W
wranglert Offline OP
i'm a regular on the jeep forum but my wife has owned a 97 passport for a little over a year now.is it true that all passports/rodeo's have limited slip 4.11 dana 44's i know mines a dana-it's 4.11-and says use a limited slip lubricant right on the cover. ?is going up a hill this morning one tire in snow other on fairly clear asphalt i almost had to use 4wd it seemed a little more slip then limited 6 months ago had one tire almost off the ground and it just went up and over anyways in 2wd. is this normal or is my limited starting to slip thanx for any help you guys can give
90 wrangler 6 cyl. 97 honda passport 84 dodge longbed 4x4
Re: limited slip [Re: wranglert] #574996 03/02/05 03:55 AM
jezeric Offline
Isuzu Moderator
Not all Rodeos/Passports have limited slip, but it was an option. If yours says to put limited slip additive in it, I'd say you're one of the fortunate ones that has it. Gearing depends on 4wd/2wd, engine, and transmission, I think, but there's still not a total agreement on exactly which came with what.
I'll let someone more personally familiar with the LS setup answer the rest of your question.
James
Re: limited slip [Re: jezeric] #574997 03/02/05 04:11 AM
ProBMXer1313 Offline
I will either have a tag on the diff that says something about it or have the G80 code on the options plate in the engine compatment on the firewall
1998 Honda Passport EXL V6 3.2L Auto SOTF 4WD
3" Calmini Lift w/ HD Track Bar, 32x11.5-16 Super Swamper SX, Aisins
[color:"blue"]http://www.CarDomain.com/ID/ProBMXer1313[/color]
Re: limited slip [Re: ProBMXer1313] #574998 03/02/05 02:53 PM
W
thanx guys i'll be checking a little closer today,but i'm fairly positive it's the 4.11 limited slip
Re: limited slip [Re: wranglert] #574999 03/04/05 12:45 PM
I
islandracer Offline
Sorry to hijack ur thread but, I'm curious to know if you got the option with the G80 code will it also contain an LSD up front in the 10-bolt diff???
B.Y.E. ~ Back Yard Engineering
Re: limited slip [Re: islandracer] #575000 03/04/05 01:19 PM
barak Offline
No , the G80 option won't include the LSD in the front differential , only the rear.I think there are very few vehicles that you could get a LSD as an option in the front as it can affect your steering a little , and if you don't compensate for it , it can get you into trouble pretty easy on wet slippery roads or snow.
Re: limited slip [Re: wranglert] #575001 03/05/05 04:51 PM
Chris Perosi Offline
Isuzu Staffer Emeritus
FYI, it's a Trak-Loc LSD, same as used in Jeeps. They do tend to have a useable life expectancy in the 60k range or so... But you can drop a No-Slip locker in there for about $300 or so, very effective.
Sometimes the Trak-Loc needs a little coercing, like a few clicks on the parking brake, to get it to engage, especially when they get older. Try that and see if it does the trick... Of course, it might just be that all the clutch packs are getting worn down...
-Chris
Chris Perosi
Isuzu Editor Emeritus
OutdoorWire, Inc.
Re: limited slip [Re: Chris Perosi] #575002 03/05/05 06:14 PM
I
islandracer Offline
Is this available as of yet (locker), or are you talking about the power-brute diff by precision gear?
I got a buddy selling me a troop and it has the g80 but, i'm only after the 2.6 motor. Motor still runs but the body is rusted pretty good. If the rear brakes aren't too shot I may just swap out axles too.
Re: limited slip [Re: islandracer] #575003 03/06/05 03:58 AM
W
hah! clutch packs you say so it might not be my imagination. when accelerating i can almost feel a light clicking, thumping and you can just about hear it also, but none of it is definite enough to be able to pinpoint its whereabouts. thanx guys i guess it's time to drop the cover
Re: limited slip [Re: Chris Perosi] #575004 03/06/05 10:30 PM
N
Nazrat Offline
-Chris
Some data that I have on the 12-bolt LSD is that our 92 with 212k miles on it still has a tight LSD. It takes 2 tubes of LSD additive to stop the chatter after a fluid change. It is also not possible to turn one wheel by hand without the other one turning (in the same direction). Maybe that Trooper just shipped with a tight one.
-Tad
1994 Trooper. 3.2 DOHC/auto. 4.77s,3xARB, OME 919HD springs. 34" Swamper LTBs
2001 Trooper "stock" <img src="/forums/images/graemlins/wink.gif" alt="" />
http://www.planetisuzoo.com
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6411 MB (Peak: 0.7611 MB) Data Comp: Off Server Time: 2026-06-22 05:05:17 UTC
