1st gen amigo hitch #576200 03/04/05 10:58 AM
blackdemon Offline OP
Hello everyone.
I need a hitch for my 92 Amigo S, I was wondering if a hitch out of a 1st gen Rodeo would fit or bolt on to my amigo, I was thinking about going to a junk yard and see if there is any rodeos with a hitch,I remember seeing a couple a long time ago but I never thought about putting one until now. Also I was wondering if they came bolted on or welded from factory. I saw one at JC Witney for about $125 which I'll probably get in case the hitch out of a rodeo won't fit and if possible how difficult is it to take it off and put it on to my Amigo, or do you think it'll be easier to buy a new one.
Thanks for any responses
Salvador
~1992 Isuzu Amigo 4x4~
* 3.2L DOCH V6
* 01 Rodeo Dash-board swap
* 32's
* custom roof rack
* custom exhaust
Re: 1st gen amigo hitch [Re: blackdemon] #576201 03/04/05 09:40 PM
randii Offline
The Amigo has four threaded holes in the center of the rear crossmember that accept a variety of bolt-on hitches. Dunno if the Rodeo has the same holes, but I know first-gen Troopers do>
If you can find a hitch that uses the holes, that will be your easiest install. You should also be able to install a receiver-style hitch that ties into the frame rails, but that is gonna be much more work than the simple bolt-on variety.
Randii
Randy Burleson
4x4Wire Managing Editor Emeritus
Mongrel Isuzu Amigo
Re: 1st gen amigo hitch [Re: randii] #576202 03/04/05 10:26 PM
Thanks Randii, I'm on my way to the junk yard, i'll look for any 1st gen troopers.
Salvador
* 3.2L DOCH V6
* 32's
* custom roof rack
* custom exhaust
Re: 1st gen amigo hitch [Re: blackdemon] #576203 03/04/05 11:02 PM
muskyamigo Offline
The 4 bolt patttern on the rear crossmember is the same as the 4 bolt pattern on pintle hitches, so if you always use a 2 inch hitch ball, some thing like this would work.
One other hitch option is on older Mitsubishi Montero's, which had something that looked like it would work well. So do H1 Hummers <img src="/forums/images/graemlins/smile.gif" alt="" />
Other wise go to your local hitch store. On my old '90 Amigo, I got the hitch for $50, installation was about $10. Seemed worth it, so I could let them fight any rusty threaded bolts/holes. The hitch was a non receiver mount style, that was quite robust. 1/4 inch plate with 2 diagonal braces.
I've also seen receiver style hitches that bolt to that bolt pattern.
Nothing you should be towing with a 1st gen Amigo would require a big frame mount receiver style hitch. The crossmember mount style doesn't rattle like the receiver type, and will handle 2000 lb of trailer just fine.
Mike W
who tows alot
Mike Walter
'98 Amigo well used
'94 Rodeo in need of help
'99 Ram CTD for hauling feather pillows
'01 unheated shop
Re: 1st gen amigo hitch [Re: blackdemon] #576204 03/07/05 12:41 AM
AIR AMIGO Offline
Dude! I was just going to throw my stock 94 Isuzu Amigo hitch away! I'll go dig for it. PM me or email me.
Keith
"AIR AMIGO!" aka 1994 Isuzu Amigo SAS with Toyota axles, 5.29's, dual ARB's, IROK's, WARN HS9500 winch, and etc.
Pacific NW Isuzu Off-Roaders
Timber Tamers #172
Re: 1st gen amigo hitch [Re: AIR AMIGO] #576205 03/07/05 01:22 AM
Sc0rp10n Offline
If for some reason he doesn't want it, come talk to me <img src="/forums/images/graemlins/kewl.gif" alt="" />
Nick <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
2000 XJ Classic - Classically a POS
1994 Isuzu Amigo XS -Sold
1972/3 CJ5 Glass body, 5" lift 34's. 5 years of work coming to an end.
Re: 1st gen amigo hitch [Re: Sc0rp10n] #576206 03/11/05 01:01 AM
Sc0rp10n Offline
I found this from jcwhitney, says it'll work, but i've been fooled by them in the past.
Nick
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6184 MB (Peak: 0.7097 MB) Data Comp: Off Server Time: 2026-07-13 09:08:52 UTC
