Head gasket replacement #576560 03/05/05 05:17 PM
madman Offline OP
I've exhausted all of my resources in my search for one small piece of info. I need to know what size tap to use to clean out the holes for the head bolts before re-assembly. and can I leave the throttle body attached to the head when removing the head?
If I can't fix it, it ain't broke.
'88 Trooper II
Re: Head gasket replacement [Re: madman] #576561 03/05/05 07:10 PM
pucci Offline
12mm x 1.50
I don't see a reason why you couldn't leave the TB on.
2.6 Trooper
2.0 Impulse Turbo
Re: Head gasket replacement [Re: pucci] #576562 03/05/05 07:14 PM
madman Offline OP
THANK YOU, THANK YOU, THANK YOU. Tommorrow Sunday will not be a day of rest. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'88 Trooper II
Re: Head gasket replacement [Re: madman] #576563 03/05/05 07:21 PM
yes, you leave all that intake junk on until the head is removed.
also, it pays to have a good place to set the head in advance. Like a block of wood for the bottom of the head, but then that should be on something higher because the IAC is hanging down on one side and the exh. manif. is on the other.
Re: Head gasket replacement #576564 03/06/05 05:16 PM
I
islandracer Offline
Do they (anybody) make copper head gaskets for the 2.3/2.6??? Could I get one made??? Sorry to hijack the thread, but since the subject is head gasket replacment, i'd like to add on than to start a new thread. Thanks in advanced!
B.Y.E. ~ Back Yard Engineering
Re: Head gasket replacement [Re: islandracer] #576565 03/06/05 11:39 PM
mlclark Offline
Isuzu Moderator
You can always get a copper headgasket made, but it will cost.
I belive that Paesco(sp) makes them. For the life of me I cannot remember the correct spelling. Anybody who makes them can make one using a stock gasket as a template.
But...a Cu headgasket is most likely not a good idea for you. Read what Kary has to say here .
Michael
Re: Head gasket replacement [Re: mlclark] #576566 03/07/05 02:53 AM
pucci Offline
that's Paeco. <img src="/forums/images/graemlins/smile.gif" alt="" />
they can also make such groovy things as aluminum underdrive crank pulleys for the 4Z's. there are a number of places that can do copper gaskets if you send them one in decent enough shape to copy. they can be reused too.
something else to consider if you are going to run high compression or boost is studding the block instead of using head bolts. seems like if you have a need for a copper hg, this is something to do in tandem.
2.6 Trooper
2.0 Impulse Turbo
Re: Head gasket replacement [Re: mlclark] #576567 03/07/05 03:46 PM
I
islandracer Offline
Michael, Thanks for the link!
Pucci, Have you done the studding? Where can I find the kit? ARP?
This is a future mod to come, still waiting for the donor 2.6 motor.
Re: Head gasket replacement [Re: islandracer] #576568 03/07/05 09:10 PM
Ed Mc Offline
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: Head gasket replacement [Re: islandracer] #576569 03/07/05 11:31 PM
pucci Offline
^^good articles, thanks for linking. <img src="/forums/images/graemlins/kewl.gif" alt="" />
no kit available, gotta buy in bulk & yep they're from ARP.
AU4.800-1LUB is the part number for the undercut studs - $7.70 ea
300-8337 pack of 10 nuts - $47.63.
200-8537 pack of 10 washers - $14.15.
haven't done it yet, but it's on the list. possibly soon, depending on how fast I can acquire & put together another head for the Trooper. I'll be sure to share whenever I do.
2.6 Trooper
2.0 Impulse Turbo
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6319 MB (Peak: 0.7400 MB) Data Comp: Off Server Time: 2026-11-19 05:16:03 UTC
