Reconfirming: Adding intermittent wipers #576807 03/06/05 03:55 PM
little_joe Offline OP
Former Admin
There had been some posts in the past on this forum about adding intermittent wipers to a truck that didn't come with them. I just wanted to reconfirm that all of the wiring for wipers is the same in Tacomas with or without intermittent wipers, and that the control for int wipers is in the switch itself.
I found an int wiper switch from a 96 or 98 Taco for $30 and popped it in yesterday. It was a direct swap and works perfectly. I also like that the wipers come on when you spray windshield washer fluid.
This may seem trivial to some, but not having them drove me nuts! We get a lot of snow in the winter and a healthy amount of rain, so now I am happy. <img src="/forums/images/graemlins/cyclops.gif" alt="" /> <img src="/forums/images/graemlins/rodent.gif" alt="" />
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: Reconfirming: Adding intermittent wipers [Re: little_joe] #576808 03/06/05 08:10 PM
hairytaco Offline
Where did you get the new int. unit and was it easy to install.....(instructions) <img src="/forums/images/graemlins/cheers.gif" alt="" />
2008 Tacoma 4x4 6spd manual SR5 TRD
Re: Reconfirming: Adding intermittent wipers [Re: little_joe] #576809 03/09/05 11:39 AM
Yup, all in the switch
Re: Reconfirming: Adding intermittent wipers [Re: little_joe] #576810 09/26/05 02:07 AM
Brand new to this and came looking for info on adding Intermittent wipers, cruise control, and bucket seats to my '06 Tacoma.
Reference your post; are you saying I can buy the Intermittent switch for my '06, and plug it right in? If so, what does "plug in" mean?
Thanks,
Gary
Re: Reconfirming: Adding intermittent wipers [Re: little_joe] #576811 09/27/05 12:50 AM
shawn p Offline
nope i know what you mean. I bought a 05 base model for 19,400 and i got a 2 speed wiper also. Drives me nuts too. I will call the dealer tomorrow and see what they want for one of these. Great post! i was just wondering this today ( as i drove in the rain)
Thanks,
Gary
plug and play means he did not have to modify anything major. you will most likely need to remove so parts from the steering wheel area.
Im not sure if this is the same for the 05-06's Im looking into this for myself. Keep checking back here for updates <img src="/forums/images/graemlins/kewl.gif" alt="" />
2006 tacoma
SR5
4x4
V6 Auto
Re: Reconfirming: Adding intermittent wipers [Re: shawn p] #576812 09/27/05 09:19 PM
triniphen Offline
where'd ya get the switch from?
Re: Reconfirming: Adding intermittent wipers [Re: little_joe] #576813 09/28/05 08:00 AM
kewlynx Offline
Did you have to get a relay also? With the older trucks, most of the wiring was in place, so you just needed the switch assembly and the relay behind the ECU to upgrade.
**ubi apis- ibi salus**
Re: Reconfirming: Adding intermittent wipers [Re: triniphen] #576814 09/28/05 02:08 PM
Former Admin
Sorry, I don't know if this applies to the 2005 and newer trucks. I got the switch from a guy in GA who was parting a Tacoma. All the wiring is in place on the older Tacomas, it's just the switch that is different. I used the FSM stickied above to verify wiring before doing this, and for instructions on handling the airbag.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6168 MB (Peak: 0.7158 MB) Data Comp: Off Server Time: 2026-06-20 08:47:37 UTC
