Nicked cam shaft? #578463 03/10/05 03:41 AM
Scott Broam Offline OP
So, I have the T in the shop (not the dealer) again to track down a persistent oil leak after having stopped a couple already. The previous leaks included:
1. Leaks at the rubber plugs at the rear of the engine and two "half moon" aluminum plugs up front, both right below the valve cover gaskets - apparently the dealer didn't replace them when they did the valve cover gaskets? The mechanic seemed to think they *should* have been done at that time, but said that he frequently sees engines where the dealer does not.
2. Leaks at the cam and crank seals - I think this is due to the previous mechanic doing a half assed job; he'd already replaced two under warranty...
Now the current leak is being attributed to a nicked cam shaft - the nick is hitting the seal. He says it looks like somebody whacked it with a hammer. He said some folks will put the seal not quite all the way in, so the nick misses the seal, but you obviously run the risk of blowing the seal - though that might have been done in the past. He asked me what work had previously been done to it - I know of the head gasket recall and a couple of timing belt/water pump/seal jobs. It's impossible to know when/how/who etc... I've almost always had oil spots in my parking space, but have rarely lost more than a fraction of a quart between fill ups (and I check every time).
He is recommending a used shaft if he can find a suitable one, otherwise a new one.
Questions -
1. Does this nicked cam shaft diagnosis sound like BS? He said they didn't notice it for a while because when the crank at TDC, the nick was on the underside of that cam. I haven't *seen* this yet, but plan to go by the shop tomorrow
2. Is a used cam shaft, providing it meets tolerances and is not burnt, crazy?
3. I've had two people ask me already why they don't just polish out the nick - is that a reasonable approach?
I know, I know, half of you are muttering under your breath "you should just learn to do that crap yourself". As expensive as this is getting I'm doing a fair bit of muttering myself!
Any input is appreciated!
Scott
[edit - to be fair to the mechanic who had to replace the cam seals before (#2 above) - it might very well have been because of the nicked cam shaft and he missed the nick, too...]
96 T100 Titan Xcab V6 2WD,Powertrax No-Slip Diff, buckets, mini-mods...
http://picasaweb.google.com/scott.broam/TruckProjects#
Re: Nicked cam shaft? [Re: Scott Broam] #578464 03/10/05 04:24 AM
thecat Offline
Mine was leaking at the dipstick seal. Weird.
Toyota master
Re: Nicked cam shaft? [Re: Scott Broam] #578465 03/10/05 07:06 AM
garym Offline
It must be nicked too much to be polished out. Even then if is is slightly off round your problem will come back. A used one in spec should be OK if the savings over a new one are worth it. Check enginebuilder.com to see if he handles stuff for the 6 cyl. The main seal on the 4 banger can wear a slight groove in the crank and the Toyota replacement seal is engineered so it seals at a slightly different point. There are sleeves you can buy to go over warn spots in cranks and then use a seal that fits the sleeve. I don't know if anything is available for that camshaft. I doubt there is an offset seal for it but you might try a search for it or for a sleeve. Seems like Felpro made it for the 20R/E. Marge?
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5944 MB (Peak: 0.6495 MB) Data Comp: Off Server Time: 2026-06-01 11:36:25 UTC
