Heater Fan Switch #579266 03/12/05 04:54 AM
Does anyone know where this Fan resistor pack is and an easy way to get to it? I have midlow and high speeds only. I assume I will need to go to the dealer for the part.
Any help would be appreciated ?
Re: Heater Fan Switch #579267 03/12/05 05:57 AM
Pull the drink holder half way out, then pull off the plastic sing that surrounds the holder, stereo, etc. Take out the stereo, remove the knobs on the fan etc. controls, and I think the face then comes off. The fan switch "clips" into place, so you have to work it backwards then out. There is a wiring pigtail on the back of it. I got the replacement at the dealer and don't remember the exact cost, except that it was way overpriced.
Good luck
W
Re: Heater Fan Switch #579268 03/12/05 06:36 AM
joelle Offline
if you search the forums, I guarantee you'll find it. I know cause I just printed it out the other day
"Sh*t or get off the pott"!
1990 4x4RNR 3.slo auto P.O.S.
"The silver bullet"! NOT!
Re: Heater Fan Switch #579269 03/12/05 05:58 PM
Perpetrator Offline
The resistor pack is mounted to the blower motor housing (passenger's footwell). There are two electrical connectors on the blower motor housing, the resistor pack is one of them.
1997 T 100 4X4 ExtraCab
5 speed, White
Worthless factory bedliner
265/75/16 Firestone Destination A/Ts
Aisin Manual Hubs
90k miles
Re: Heater Fan Switch [Re: Perpetrator] #579270 03/12/05 07:31 PM
OK Maybe I misunderstood; When I was having trouble with my fan, the problem was in the switch itself, it having burned out some of the resitors inside. That's what I was referring to above.
W
Re: Heater Fan Switch #579271 03/16/05 03:10 AM
i had the same problem with the melted switch, $60 from the dealer. i'm cheap so i just took it apart and made it so that speeds 1 and 4 work.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5997 MB (Peak: 0.6686 MB) Data Comp: Off Server Time: 2026-10-29 16:31:04 UTC
