shackle install
#579442
03/13/05 12:30 AM
So I'm trying to disconnect the rear springs so I can install my shackles and in the process one of the bushings gets all chewed up. So I bought some poly bushings to replace them... only problem is, I can't get the rest of the old bushing out. Does anyone know of a good way to get the metal piece (not the one the bolt goes through) but what the rubber is attatched to out? Thanks!
1994 P'up, 22RE, K&N, LCE exhaust sys (header, cat, muffler, 2.25" pipe), 1" RB seat lift, 1" RB body lift, 1.5" rear lift via shackles, Rancho 5000's, 33" Pro Comp M/T's, 4.88's w/ Aussie lockers front & back
Re: shackle install
[Re: toy94x4]
#579443
03/13/05 12:45 AM
Assuming this is the pressed in spring eye bushing: Drill a series of holes around the center sleeve: ![[Linked Image]](http://c-67-170-224-64.client.comcast.net/Photos/103_pana/P1030161.JPG) The push out the sleeve and use a saw to cout out through the outer sleeve: Then wedge a screwdriver or chisel into the spring eye and hammer out the sleeve. Or, hydraulics are your friend: ![[Linked Image]](http://c-67-170-224-64.client.comcast.net/Photos/103_pana/P1030163.JPG)
Re: shackle install
[Re: toy94x4]
#579444
03/13/05 01:03 AM
Toyota Moderator
Roger Brown has covered this issue in Toyota Trails and on this bulletin board, apparently it is fairly common. Roger says "Those bolts tend to rust to the steel sleeve inside the spring bushing. You need to break the grip of the rust to get it out. If its on the driver's side, try hammering the end of the bolt, leaving the nut on the end. Another option to try is some heat from a torch to heat up the bolt. Or try a thin pry bar between the spring hanger and try to press down on the sleeve while prying against the hanger and bolt head. Often you can get enough pressure on the sleeve for the teeth on it to dig into the opposite side of the hanger and hold it in place so you can turn the bolt and break it free. Some PB Blaster or other penetrating oil might help if you can get it into the sleeve. If all else fails, a Sawzall or cutoff wheel will cut the bolt apart to get it out, then replace it with a 9/16" SAE or M14 bolts."
Re: shackle install
[Re: DirtyHarry]
#579445
03/13/05 01:18 AM
Thanks guys. I'll give that a try.
Re: shackle install
[Re: toy94x4]
#579446
03/13/05 09:38 AM
The sawzall did the trick on the right rear. And for the left I took the whole spring pack out and used an air hammer and a 1 1/8" socket to press it out. Thanks for the advice. You guys helped me out once again.
