need some welding cart ideas #579546 03/13/05 09:44 AM
Ganoid Offline OP
I modified my cart to accept my new toy but Im at a loss of ideas for all these wires. I have the mig gun secured and the power cords are functional. Im having trouble finding a good way to mount the grounds and plasma gun now. Here is what I have so far...
Any ideas?
The plasma gun is like 25ft long.
Maybe we could see some pics of other rolling carts?
90 Xcab V6
3.0 Rebuilt/Balanced
P/P w/OS valves
Downey Hdrs,Jacobs Ign
5.29's,Tru Trac+Lockright
4"TG SAS+Rear Kit on 35's
(DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />)
www.performancecylinderheads.com
Re: need some welding cart ideas [Re: Ganoid] #579547 03/13/05 04:21 PM
Dandeman Offline
Toyota Moderator
Rather than a cart, you might consider building a welding table with casters on it so it can be rolled around in the work area..
Then have a shelf underneath that you can set the welders, plasma cutter and various grinders, etc.
There will be more room for the cables, especially if you had some projections that you wind the cables on. You may have seen these on welding trailers or welders mounted on trucks..
One thing for certain, you need some type of brake on the casters so the table doesn't roll around as you are working on it.. very annoying..
not a very good pic of mine...
I just finished building a second (and much bigger table) for a friend (sorry no pics yet, I'll take some and post them later)
We had a 1/4" 4x8 foot steel plate (about $190.00) cut up to make a 6' 6" long by 28" deep table top, with vertical back plate aligned to a perfect 90 degs (very handy for clamping stuff to) and a shelf that runs the entire length underneath.
Very heavy, but solid and easy to roll around on its steel casters..
His MIG welder, cables, gas bottle, grinders, MIG cables and hoses are coiled underneath.. As long as you are welding a part on the table, you don't even have to mess with the grounding cables since they are attached to the table..
The only cord running to the table is the 240v AC supply..
Re: need some welding cart ideas [Re: Dandeman] #579548 03/13/05 07:44 PM
NCBBA2358 Offline
Your cart set-up is great for a portable workspace. If you have the flexability to set up a workspace like sunder is running, better. I think you are more interested in something a little more mobile so that you can tote your gear around when you need to. This works well when you have a truck or trailer to mount it all to, but not so well when you are trying to do a compact deal for fitting in a smaller shop.
91 Jeep Wrangler YJ, carpet, tires, trailer hitch. yea....
Re: need some welding cart ideas [Re: NCBBA2358] #579549 03/13/05 08:49 PM
L
Landmonster Offline
How about making two of those out of sheet metal, and mounting one on each side of your cart? Sort of like those garden hose hangers.
Re: need some welding cart ideas [Re: Landmonster] #579550 03/16/05 06:58 PM
Bigpoppax2 Offline
Everybody rags on the harbor freight tools, but I spy!
I see that el-cheapo harbor freight chop saw. Mine has done a good job for me.
As for the welding cart/plasma cutter I'd like to have that problem. I would think the idea above like the hose reel would work well.
Joe
Moderated by  4x4Wire, PHIL_
PHP: 7.4.33 Page Time: 7.595s Queries: 15 (0.009s) Memory: 0.6088 MB (Peak: 0.6913 MB) Data Comp: Off Server Time: 2026-11-17 06:04:19 UTC
