Re: new head - engine not running right
[Re: swamprocket]
#579810
03/17/05 08:46 PM
double check your spark plug wires.... and make sure your thermostat isnt in backwards. Its always the easy things that get over-looked. Running a tap down your head bolt holes will insure proper torque.
#579811
03/18/05 12:11 AM
The way I burp my 22re is: park with front slightly higher than rear top off rad with coolant set heater control to hot run with cap loose for awhile(may vary} Keep an eye on the Temp gauge!! the coolant may spillover once the thermostat opens top off rad with coolant allow thermostat to cycle a couple times you can tell by looking at the coolant flow(cap off) top radiator off and cap tight fill over flow jug to "Hot" line drive around the block allow to cool then check coolant level. done.................Karl
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5901 MB (Peak: 0.6404 MB) Data Comp: Off Server Time: 2026-06-20 16:46:45 UTCValid HTML 5 and Valid CSS
