Page 2 of 4 1 2 3 4
Re: 3.0 crank bolt recall... [Re: TobyB] #580036 03/15/05 03:57 AM
FrankR Offline
I'd add 'timing pulley recession' to the list of possible causes for loosening.
Toby -
Interesting observation. I don't remember from my tear-down if the crank nose was a taper or a straight cut leaving a shoulder for the timing sprocket to butt against. Are you saying it chewed into a shoulder on the crank or spread up and over a taper?
Either way though the recession result could be from the timing sproket spinning on the crank after the key broke, couldn't it?
Frank
it's a really thin interface... [Re: FrankR] #580037 03/15/05 04:09 AM
TobyB Offline
on the 4 cranks I looked at,
the 'nose' that the pulley butts into is a radiused edge, and only about 3/32" of metal actually connects- AFTER the pully's smushed into conformance with the (much harder) crank.
Which reminds me- I should go retorque mine soon, eh?
t
'89 V6 4dr- '4- Doris'
Re: it's a really thin interface... [Re: TobyB] #580038 03/15/05 04:54 AM
52degrees Offline
I just had mine off for the timing belt job. No way to torque it properly and it's the old one too. I really need to order the new one.
Anyway, it's on there about this tight;
Btbtbtbt, btbtb, btbtb, btbtbtbtbtbbtbtbtbttbtbtbtb.
Hope it holds.
Clay
KG6VNX
Re: 3.0 crank bolt recall... [Re: FrankR] #580039 03/15/05 05:04 AM
DaphneD Offline
Maybe we need to add "crank bolt torque check" to the list of yearly routine maintenance. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 3.0 crank bolt recall... [Re: DaphneD] #580040 03/15/05 05:06 AM
52degrees Offline
Geez, more like daily for me. <img src="/forums/images/graemlins/scared.gif" alt="" />
How much is that bolt?
Clay
KG6VNX
Re: 3.0 crank bolt recall... [Re: DaphneD] #580041 03/15/05 05:09 AM
FrankR Offline
That's probably not a bad idea at all, but I haven't heard of anyone on this forum that has experienced a problem after replacing the old bolt with the new one, have you? Does that mean that:
1) the new bolt is superior?
2) we're more accurate than the factory was?
3) it takes 10-15 years for the dang thing to blow up?
Beats the Hell outta me, Lieutenant.
Frank
Re: 3.0 crank bolt recall... [Re: 52degrees] #580042 03/15/05 05:10 AM
FrankR Offline
'Bout 5 bucks and a whole lotta work - but not as much as if it breaks. <img src="/forums/images/graemlins/wink.gif" alt="" />
Frank
Re: 3.0 crank bolt recall... [Re: FrankR] #580043 03/15/05 05:17 AM
DaphneD Offline
I've said it before, and I'll say it again - this is a $5 15min fix. It is well worth your time and money.
How many people have re-checked the torque on their crankshaft bolt through the years? However, remind me and I'll re-check mine in Aug to see if it's gone funny. <img src="/forums/images/graemlins/wink.gif" alt="" />
It takes far less than 15yrs for this thing to creep up. As stated, usually happens within a short period after a timing belt change. Only seems to take one episode of old crank bolt "tampering" to bring down the beast. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: 3.0 crank bolt recall... [Re: FrankR] #580044 03/15/05 05:19 AM
52degrees Offline
I'm still not clear as to the part number. I'll order it tomorrow if I can get the fer-sure right part number.
Clay
KG6VNX
Re: 3.0 crank bolt recall... [Re: DaphneD] #580045 03/15/05 05:21 AM
FrankR Offline
I don't remember if I have two spanner holes in my pulley or not. I think I'll check and if I do I'll get a spanner to fit and put that job on the maintenance list. Good suggestion.
Frank
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6441 MB (Peak: 0.7531 MB) Data Comp: Off Server Time: 2026-06-07 09:43:52 UTC
