Stock Rear height
#581165
03/16/05 10:33 PM
Recently installed new "no-name" springs and my shocks look like they are almost fully extended. I'm thinking these springs have more than the stock arch. Is there a standard height measurement for springs? drum to fender? perch to shackle? ground to fender (tire dependant)?
1988 4Runner, V6 Auto, Mostly Stock 32 x 9.5 Swampers
Re: Stock Rear height
[Re: The_Rusty_Gear]
#581166
03/17/05 12:02 AM
Measure from the upper lip of the rim to the fender. (state which size rim alos, 15", 16'?)
89 4Runner 3" BL, M/T locks, 33"bfg mt, bilstein, Kayline, tubebumper, toyotafiberglass panels TBI: Elocker,3.4 w/ORS,b+b,S2Sstg2cams,arias pistons,P+P intake,TRDs/c,URDpullies+7th,downey headers,MAPECU2,WEGO WB, SupraMAF,walboro255,stg4clutch, EPaOo2 sim
[Re: Greg_Canada]
#581167
03/17/05 12:18 AM
Definately a 15" rim. Will post my height tonite. What measurement should I be getting? (Should only be a 1/2" difference between 15 and 16" rims, right?)
#581168
03/17/05 12:34 AM
It's up in the air, i rememeber a thread from about a year ago talking about it. Mine measures 13.5" front, 12" back, and my springs are sagging. I'd say around 13-14" is stock.
[Re: Greg_Canada]
#581169
03/17/05 01:14 AM
Mine was about 14 rim to fender before cranked t-bars and body lift.
[Re: TAucoin]
#581170
03/18/05 04:27 PM
Well, I measured and I was at 13.5" - Right about where I should be. Still looks strange that my shocks seem to be almost fully extended . . . . . (I even have shocks supposedly 1-2" longer than stock too!)
#581171
03/18/05 05:04 PM
Could be whatever chart the shock place used to look up the 1"-2" longer shock is incorrect. I long ago gave up on what the applications sheets say and just measure for myself and order by p/n: http://www.4crawler.com/4x4/Rancho.shtmlFor the rear, I found the Rancho 5144 was about the longest stock you could stuff into the stock mounts and still have full compression to the bumpstops.
