Re: Can I use a Holley carb on my 2.6? [Re: Racer4] #581354 03/17/05 08:29 PM
Monty Offline
Stock intake modified to accept a Holly carb.
I took a rochester carb base to holly carb adapter plate, and tig welded it to the intake. The plate can be bought at any speed shop. You take the the rochester side (smaller side) and weld that to your intake.
I used a 500 cfm Holly carb jeted down to .62
1989 Raider V6/MT
2005 Jeep Liberty CRD Turbo Diesel
Re: Can I use a Holley carb on my 2.6? [Re: Monty] #581355 03/17/05 11:54 PM
dylanb Offline
I was just getting ready to tell you ask Monty, I was asking him about it a couple of months ago. Check out his site, it'a a nice rig.
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
Re: Can I use a Holley carb on my 2.6? [Re: FrankR] #581356 03/18/05 02:10 PM
The choke is actuated by a 12v lead taken off the ignition switch - 12v heats the coil which moves the choke valve - about the simplest choke arrangement you can have.
I don't know about OE electric carbs/ECU, but all Holley electric choke models I've seen are ignition switched on/off.
Frank
The only draw back to that design is, what if you are sitting in the truck listening to the radio on a cold day with the engine off? You will be heating the choke coil and it will be difficult to crank. I used an oil pressure switch in series with the ignition to eliminate that problem.
Second note, I would rather have a holley than any other carb for off road. Not to mention that they are very adaptable to nearly any application (if you know how to tune it properly)
If you dont know how to tune a holley (and I dont mean just tweaking the screw adjustments) you will not enjoy that carb.
Re: Can I use a Holley carb on my 2.6? #581357 03/18/05 03:21 PM
FrankR Offline
If your radio is wired to the ACC circuit and your choke is wired to the IGN circuit (as they should be) then if you want to listen to the radio the ignition switch should be in the ACC position which takes the IGN circuit off-line. The easiest and best method is to take the choke lead off the coil voltage before any voltage dropping resistors that may be in the circuit.
Me too, but most marine units are even better for off-road use - vented into the carb throat and some are designed to reduce the chance of leakage. I certainly agree that a Holley is nearly infinitely tunable - with many parts available.
True, but the 2bbl units are much simpler to adjust and tune than the 4bbl models. I've always maintained that the bad thing about a Holley carb is that you have to set it up correctly but the good thing is that you can - provided you take the time to understand it.
Frank
Re: Can I use a Holley carb on my 2.6? [Re: FrankR] #581358 03/18/05 06:17 PM
Jamez Offline
Is it a given that when switching to an aftermarket carb you lose the factory intake?
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: Can I use a Holley carb on my 2.6? [Re: Jamez] #581359 03/18/05 07:05 PM
FrankR Offline
I'm not familiar with the 2.6L intake, but from posted comments I would assume that an adapter plate between the 2.6L intake and the carburetor could be made to work. It's commonly done on other engines to adapt a Holley to a Rochester or other mount. Here are some examples:
Adapters
Here's a Holley 2bbl/Weber single throat adapter - won't work on the 2.6L dual port intake, but just for an idea:
Holley/Weber
The staged dual throat carb is designed to provide better fuel metering and atomization at low rpms so some attention is needed when switching to a larger CFM 2bbl sychronous-opening carb like the Holley design in order to keep from having a low-speed bog. Good throttle response can usually be achieved, but may require a jetting change, accelerator pump and/or pump cam change and a power valve change to get it right.
When it comes to carburetors there's still nothing better for tuning them than a good seat-of-the-pants gauge, a good eye for reading plugs and a box of parts.
Frank
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6200 MB (Peak: 0.7079 MB) Data Comp: Off Server Time: 2026-06-17 10:26:29 UTC
