adding turbo to na diesel pup
#582244
03/19/05 12:37 AM
Hi, i'm new. I have a 83 pup na diesel. I was surprised to get no results when searching for info on adding an aftermarket turbo to an isuzu na diesel.
I'm sure someone around here have done it. Any info available?
Re: adding turbo to na diesel pup
#582245
03/19/05 08:43 AM
C223?
There are plenty of kits available for those, but it'll be cheaper and more rewarding if you piece it together yourself.
Keep the boost down and you should be fine. The factory turbo engines normally run lower compression to keep the peak compression at a sane level.
#582246
03/21/05 04:34 PM
You might need to replace the oil pump with the turbo model. I remember hearing that that is one of the differences between turbo and NA. This is for the C223T.
[Re: svanmatr]
#582247
03/22/05 07:24 AM
C223
I can only find one kit by Denco. And no prices listed. Does anyone know of any others?
thanks, will check into oil pump issue.
p
#582248
03/22/05 04:41 PM
I'd suggest extreme caution in this endeavor. The turbo'd C223 have totally different connection rods, an additional set of tubes to spray cooling oil on the bottom of the pistons and a few other reinforcements needed to accept the additional force derived from the turbo. Slapping one on isn't going to work. The standard C223 is a slow engine, but highly reliable. I have a Pup (LUV) {funny to see the puppyluv name I thought of that some time ago as well!}. Ther are also issues with the fuel pump delivery. Sorry to be a wet blanket but would not want to see you blow an engine up. Eric, VA
[Re: kravdraa]
#582249
03/22/05 05:57 PM
Am I better off thinking about a complete engine swap? I might have to blow up the engine first. <img src="/forums/images/graemlins/evil.gif" alt="" />
Are C223T's hard to come by? Can't find any on an initial search...
#582250
03/23/05 01:28 PM
I saw one on e-bay yesterday. Search under isuzu diesel, or chevy luv. Is your current engine not behaving itself? I thought about putting a turbo on mine a few years ago until I researched the subject and decided to leave it alone. I am in Northern VA. You? Eric
[Re: kravdraa]
#582251
03/23/05 07:00 PM
current engin is fine. just want more power. and something to do. I probably won't mess with it anytime soon. it only has 100k miles.
#582252
03/23/05 09:26 PM
with 100K on it a good project woul dbe to change the timing belt. General wisdom is every 50K it should be done. If it breaks when the engien is running the engie gets destroyed internally. :-) Eric
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6164 MB (Peak: 0.7020 MB) Data Comp: Off Server Time: 2026-06-17 05:12:03 UTCValid HTML 5 and Valid CSS
