Re: Dana 35 confused numbers....
[Re: BigJim]
#584904
03/26/05 04:47 AM
Thats nice... Thank you Big Jim.
91 Jeep Wrangler YJ, carpet, tires, trailer hitch. yea....
[Re: NCBBA2358]
#584905
03/26/05 09:07 PM
Line D2 could indicate that there are 3.07:1 gears, so, is the rear just a heavier case with the same gear set? Answered your own question. Yes, the rear axle is a heavier (debatable with the D35) everything with the same gear ratio (should be anyhow).
#584906
03/27/05 12:11 AM
During the process of re-gearing to 3.73's (did the rear first) I decided I wanted to see how bad the whole system would sieze with different ratio's. I went to a parking lot with old crumbly asfalt and threw it in 4wd. I went from 5 to 0 like someone hit the brakes. If you have different ratio's, you'd know about it the first time you tried it in 4wd.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5948 MB (Peak: 0.6496 MB) Data Comp: Off Server Time: 2026-11-02 23:31:28 UTCValid HTML 5 and Valid CSS
