Diff Oil #585583 03/26/05 06:29 PM
Jake97T Offline OP
I put 4.88s in my T last year and i just got around to changing the gear oil today, the oil came out like a sparkly silver grayish color, a little gritty, should i be worried or can i just pass it off as the glaze and junk on the fresh gears i put in??? <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: Diff Oil [Re: Jake97T] #585584 03/26/05 09:30 PM
surlynkid Offline
when you installed the 4.88's, did you immediately change the diff oil after a couple of hundred miles?
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Diff Oil [Re: surlynkid] #585585 03/26/05 09:34 PM
Jake97T Offline OP
nope, didnt know i needed to at that time, probably should have researched it a little, i had the work done at the dealer, they didnt say nothin' bud im sure they would be glad to have me back in after a gear failure or two...im not really worried about it right now anyway, havent received any answers yet on if i should be.
I changed the front a little later today, the oil looked alot better in the front, since it gets used so rarely...
There were no chuncks of metal or anything, there was one small piece of filing on the drain plug magnet, otherwise it all looked like a little metal glaze.
Re: Diff Oil [Re: Jake97T] #585586 03/26/05 10:38 PM
surlynkid Offline
always change the diff fluid after a few hundred miles after installign new gears. they told you nothing about breakingin gears. drive 10 miles (easily), and then let it cool. then drive it. hopefully you will be okay, but what you did is not the way to break in new gears.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Diff Oil [Re: surlynkid] #585587 03/26/05 11:45 PM
Jake97T Offline OP
Yup they just gave the truck back to me and said that'll be $1100, and then i was off and going. I wasnt hard on the diff when i first got it setup. Im just worried that the fluid not being changed for the last 12k miles might have hurt it,
I read somewhere it was probably gray because water got in there, ive never crossed any streams or anythings, but ive been in some deep water holes, i guess it got contaminated, im sure itll be alright though, diffs are pretty tough, i guess what happened wasnt exactly ideal.
Re: Diff Oil [Re: Jake97T] #585588 03/27/05 02:00 AM
surlynkid Offline
the color is that phosphor coating or whatever it is on new gears.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Diff Oil [Re: surlynkid] #585589 03/28/05 11:46 PM
sluggo Offline
OK, I'm in the same boat. I had an LSD installed about 8k ago. No mention of getting the gear oil changed. I haven't noticed any problems, thank goodness but I should be getting that rear diff gear oil changed ASAP shouldn't I? Any recommendations on a good synthetic?
Re: Diff Oil [Re: sluggo] #585590 03/28/05 11:55 PM
surlynkid Offline
gear break-in is important for new gears. personally, i would chnage things pretty quickly after a LSD or locker install just since everything got adjusted. with just an LSD, you are probably better off than someone who got new gears.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Diff Oil [Re: sluggo] #585591 03/28/05 11:55 PM
Jake97T Offline OP
I put some Mobil 1 full synthetic in mine, got it for about $7.99/qt. you'll need 3.1 qts for the rear diff, and 1.8 qts for the front, 1.1 for the transfer case, that is if you feel like going nuts on all the diffs and T-case.
Re: Diff Oil [Re: Jake97T] #585592 03/29/05 12:02 AM
Jake97T Offline OP
Spoke to the Toyota Stealership today, they said there "isnt a gear break-in period", kind of strange they wouldnt know anything about that. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6359 MB (Peak: 0.7594 MB) Data Comp: Off Server Time: 2026-05-28 18:41:05 UTC
