Gen 2 Trooper manual? #586567 03/29/05 08:42 PM
gotdurt Offline OP
Anyone know where to find a shop manual in electronic form (pdf)? All I need is a schematic for the 5-speed manual trans ('94).
Casey Fry
Leander , TX
94 Trooper (33" BFG muds, home made trail rig)
2000 Amigo (grocery gitter)
http://home.earthlink.net/~cfry129/
www.clfry.com
Re: Gen 2 Trooper manual? [Re: gotdurt] #586568 03/30/05 01:09 AM
N
NotSoSimple Offline
Have you tried a Haynes or Chiltons manual? Not sure if they have an exploded diagram or not...
'90 Trooper - 2.6L 5-Speed - 1" BL - Custom Roof Rack+2x55watt ProComp - Herculined Interior - Pace Setter Header - Dynomax Super Turbo - K&N - ProComp ES3000 Shocks - Optima Red - MSD 6A - 31" Kumho Mudders - Black Rock Crawlers
Re: Gen 2 Trooper manual? [Re: NotSoSimple] #586569 03/30/05 02:57 PM
gotdurt Offline OP
I have a Haynes manual, but it's for gen 1 Troops. I don't think there is one for gen 2, at least not that I have found. Some things are similar, but the 5-sp tranny looks different. I've developed a nasty oil leak, looks to be coming from the top of the tranny, maybe at the shifter. I just want to look at a schem to confirm that this is likely, before I drop it.
Casey Fry
Leander , TX
www.clfry.com
Re: Gen 2 Trooper manual? [Re: gotdurt] #586570 03/30/05 03:01 PM
Happy Birthday Richard Saylor Offline
I'd pull the shifter boots and look around under there. Once those are off, you should be able to peak through the hole in the body. I'd do that first to try and save you time.
Who just gone done pulling the transmission himself (what a pain in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" />)
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Gen 2 Trooper manual? [Re: Richard Saylor] #586571 03/30/05 03:08 PM
gotdurt Offline OP
Yea, I've gone that route (way back when the leak was just a wee one), but as I recall, you can't see much from the top, and you especially can't get to much, other than the shifter socket.
Casey Fry
Leander , TX
www.clfry.com
Re: Gen 2 Trooper manual? [Re: gotdurt] #586572 03/30/05 09:33 PM
langforg Offline
There is a downloadable manual either on this forum or on Planet Isuzoo. Just click on forums and do a search. I believe that it is for a 92-97 trooper.
95 Trooper,3in Lift,15x10 AR-23 Wheels, 33x12.50 BFG AT's, SuperWinch Hubs,Rock Sliders,Tie-Rod Shields,Cross-Drilled Brake Rotors,ARB Bull Bar...,looking for cheap winch.
PHP: 7.4.33 Page Time: 4.982s Queries: 15 (0.005s) Memory: 0.6103 MB (Peak: 0.6804 MB) Data Comp: Off Server Time: 2026-06-17 07:34:42 UTC
