Re: 3.2 knocking/clacking [Re: rubo] #586779 04/02/05 04:05 AM
muskyamigo Offline OP
forget about adjusting the valves. They are hydrolicaly adjusted by the oil pressure (who ever tells you otherwise dosn't know nothing about these engines).
hmmmm....How sure are you on that?
The Isuzu Owners Manual for my 1998 Amigo says the lifters need adjusting every 60,000 miles
There is a sticker on the hood with vacuum line diagrams and hot and cold valve clearance tolerances.
My 1998 Amigo/Rodeo Helm manual lists tolerances and adjusting/shimming procedures for the 1998 DOHC 3.2L V6.
The dealers had no problem looking up parts and labor for the task. I called them and asked them how much it cost to have it done.
I find it odd that all of these vehicle and year specific sources seem to indicate that the valve lash indeed does need to be and can be adjusted.
the 2.2L 4cyl DOES use hydraulic lifters however.
FWIW I have tried the racing the engine technique with no luck. I've been driving like normal as well.
Mike
Mike Walter
'98 Amigo well used
'94 Rodeo in need of help
'99 Ram CTD for hauling feather pillows
'01 unheated shop
Re: 3.2 knocking/clacking [Re: muskyamigo] #586780 04/02/05 05:27 AM
jeepdriver Offline
My wife's Mazda Millenia did this same thing at 34,000 miles, the engine had a stuck lifter. I drained some oil out, added a quart of engine flush and ran it about ten minutes, did an oil change and added some Marvel's Mystery Oil, and ran it for a few hundred miles. I changed the oil again, and the noise seems to have gone away.
Too many 4x4's, not enough time or money
Re: 3.2 knocking/clacking [Re: muskyamigo] #586781 04/02/05 09:00 AM
rubo Offline
i'm gonna leave this to some one who actualy knows the DOHC engines (unless i'm gonna get a go ahead on fixing the one that is knocking in my shop).
I wouldn't trust the dealer too much. They are more than glad to take your money & do absolutley nothing (i deal with many of them every day).
Again i'll let some one with more experience with these engines chime in.
"If i can't crawl over it, i'll fly over it"
rubo
'96 Amigo 4x4, 3.2L V6, 4L30E, D44 rear, SOA, 1" BL, undergoing surgery.
'00 Rodeo LS 4x4, 3.2L V6, OME 919 Springs, front cranked to match,1" BL, 265/70x16 Scorion A/T's.
Re: 3.2 knocking/clacking [Re: rubo] #586782 04/03/05 03:53 AM
NATO308 Offline
The Isuzu 3.2/3.5 liter engines have mechanical lifters. They are adjusted by replacing solid disc shims that are captive by the guide that goes into a polished port in the head that the valve springs valves fit in. I doubt very seriously that a shim or guide has come off or apart since they are both pretty substantial pieces of solid machined steel.
As a side note, I have found the easiest way to adjust the valves is to take measurements of the lash gap and pull the cams to replace shims, IF NEEDED. Once you have pulled the cams from the head and can identify the alignment marks, it is no big deal. Since they are gear driven and not directly connected to the timing belt, it takes about 15 minutes to pull both cams on one side and put them back on. Takes ten times longer to pry all the lifter shims from the valve stem cups, than to pull and replace the two cams.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
Re: 3.2 knocking/clacking [Re: NATO308] #586783 04/11/05 04:31 AM
All right, bring this one back (I was out of town for work last week). Despite my best efforts to find something else wrong, it appears I have the wonderful rod knock.
Valves were mostly on the loose side of spec, ie, at the maximum gap, except the exhaust valves on a cylinder on the passenger side which was a couple hundreths over (~.02)
Several opinions from fairly knowledgeable people all said rod knock.
So now I am in the process of pulling the engine.
Mike W
Mike Walter
'98 Amigo well used
'01 unheated shop
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6172 MB (Peak: 0.6831 MB) Data Comp: Off Server Time: 2026-05-29 18:56:35 UTC
