Re: Ways to stop a running truck your locked out of.
[Re: javven]
#587068
04/01/05 06:19 PM
I'd still shoot for the coil wire if you could get at it. Again, tough but you could keep a wire in your frame or bumper pretty easy. I was trying it with a bit of the wire they use to tie up chain-link fence. Looks very possible. You need a good length of it and again, a good light but it looks doable. Not sure if this would damage the vehicle or not.
Stopping a car with a firearm:
Pistol: Occupants (depending on situation) Tires Radiator (hot day in LA, speeding car - it won't stop instantly but it'll stop quick).
Rifle: Occupants (again, depends on the situation) Engine block or transmission (once the fluid is gone an auto will obviously not be movable) Radiator
Pistol assumes a patrolman in an 'oh #@$' situation. Rifle assumes a marksman with at least some time to make a shot. LE and Military will have different views on the subject...
(/hijack) You beat me to it, but a bullet to the block - pistol, rifle, it doesn't matter - will stop a car pretty damn fast. I've alway had good luck with a coat hanger. No damage to the vehicle and easily stored in an inconspicuous spot under the truck. Slimjims won't work on Monteros. There's a plate in the door frame above the lock rod. You'll pop the rod out of its clip, but you won't pop the lock.
87 Montero, bought new, by me - 88/89 intercooled Starion Turbo engine- with awesome audio.
[Re: sparkem]
#587069
04/01/05 06:52 PM
I'd put a brick through my window before I took a chance of hurting my mill.
Change your oil hot and often. 07 Taco V6 4WD 5-Auto
[Re: javven]
#587070
04/01/05 07:06 PM
I'd like to see the expression on someone's face if he unplugged a coil wire with a coathanger. <img src="/forums/images/graemlins/lol.gif" alt="" />
Man that feels good! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Frank
[Re: FrankR]
#587071
04/01/05 07:29 PM
I'd get over it
[Re: javven]
#587072
04/01/05 07:43 PM
Slim jims work on GenIIs...done it several times to both of ours.
[Re: stony-man]
#587073
04/01/05 07:53 PM
Slim jims work on GenIIs...done it several times to both of ours. You may be right. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I was referring to Gen Is. That's all I have real experience with.
[Re: dadrab]
#587074
04/01/05 08:15 PM
Post the question on this board and wait for a consensus. While waiting, you will surely run out of gas!
90 LWB Montero, 270k, 265/75R16, 16x8 ARE Bajas, Budget Lift, Towbar, Aux Brakes (towed with camper), Jotto Desk, remote oil filter 92 bone stock base model beater Parting out 4 more
[Re: TommyM]
#587075
04/01/05 09:39 PM
Post the question on this board and wait for a consensus. While waiting, you will surely run out of gas! <img src="/forums/images/graemlins/lol.gif" alt="" /> Good one. NO ONE answered my question in this thread...I'm getting a complex <img src="/forums/images/graemlins/scared.gif" alt="" />...I'm going to start a new account, and say I'm a recently divorced swimsuit model chick in the signature...bet I get DROVES of answers. <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: dadrab]
#587076
04/03/05 10:24 PM
Gen I are easy to break into. A wire/hanger/hot dog stick thru the sliding window overlaping parts. I used a hot dog stick and punched the rear door lock to open. Bob Shaw
[Re: BobShaw]
#587077
04/07/05 06:29 PM
Really hefty shot of CO2 into the intake, and I guarantee it quits. Have to keep the CO2 going until the engine stops rotating.
Push the hidden rear door lock button and climb inside.
Push the remote unlock button (or rewire the hidden rear door button).
A 38 and some 9mm won't bust an engine block reliably. A .357 or better will, almost every time, as will most any rifle slug.
BTW, moonshine runners used to carry a tank of pressurized oil/soapy water/bleach mix with spray nozzles on the back bumper to discourage pursuit. Hard to chase somebody if you keep knocking down trees...
