Page 2 of 6 1 2 3 4 5 6
Re: Rear bumper project/ plans... [Re: onebadtrooper] #589025 04/05/05 07:07 PM
Chef Offline
I just had to comment.
That is going to be a sweet looking rear bumper. Like mentioned before, my only worry is the ends that stick out too far. A feathering into the body will do it justice and let it flow better.
Just wanted to tell you your rig has been an inspiration for my second 1st gen. Thanks!
BTW, Those tires are stout! Look at the first pic and it looks like your rears are turning even when they are standing still. KEWL. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Chef
91 T, 2.8 A/T, Weld Wheels, 33 A/Ts, 3? Calmini lift & stabilizer, OME leafs & shocks, ARB lockers F&R, 5.38s F&R, Superwinch Hubs, full roof rack, brush guard, One Bad rear bumper, Hella fog/driving lights
Re: Rear bumper project/ plans... [Re: Chef] #589026 04/05/05 07:20 PM
onebadtrooper Offline OP
Thanks man, thats a nice troper you have, I wish i had ARB's hopefuly in about a year i'll have one. And I'll rework the sides. And the tires are pretty big, 13.5" wide.
Thanks man, and I'm glade i could help. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Rear bumper project/ plans... [Re: onebadtrooper] #589027 04/05/05 11:14 PM
I modified it alittle bit. I still have to do some work on the bottom, I don't like how it goes to a piont, on the part that wraps around. I added two more angles to get the sides closer to the troop. I think it looks alot better.
Before
After
Re: Rear bumper project/ plans... [Re: onebadtrooper] #589028 04/06/05 02:06 AM
CPOM Offline
My only comment is to be careful with the tight clearances as the frame can flex and shift the body sometimes. You don't want to hear godawful squeaking sounds.
CHRIS
98 Amigo, 92 Pup
Re: Rear bumper project/ plans... [Re: CPOM] #589029 04/06/05 02:11 AM
oh yeah, i know how that is. when i make it out of steel i'll have all the right clearances. I found that out the hard way with the rock sliders <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: Rear bumper project/ plans... [Re: onebadtrooper] #589030 04/06/05 09:52 PM
Madcat Offline
After
Agreed much better
Madcat <img src="/forums/images/graemlins/kewl.gif" alt="" />
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
Re: Rear bumper project/ plans... [Re: Madcat] #589031 04/08/05 07:13 PM
F
Frisky Offline
Any new pics now that you have some steel in the garage?????
1992 Isuzu Rodeo 2WD (some assembly required). "If it doesn't fit....Force it!! If it breaks, it needed to be replaced anyway."
Re: Rear bumper project/ plans... [Re: Madcat] #589032 04/08/05 08:24 PM
Curtis Johnson Offline
After
Agreed much better
Having taken damage at Moab Rim on this very spot on the body.....What if you added side protection all the way to the back of the wheel well? Wouldn't need to be real thick about 2 inches wide and 2 - 3 inches tall. Then put your angle there behind the trim piece to deflect you away from the rocks and trees. I do think the plate around the corner adds the right touch and fills that gap nicely.
I have dents on both rear corners. Oddly enough I just had all the dents fixed and it painted before I went up there and banged in the rear corners.
All long as your in the planning stages you may want to think about that option also.
Just a thought,
Curtis J
Re: Rear bumper project/ plans... [Re: Curtis Johnson] #589033 04/08/05 09:01 PM
yeah i've been thinking of that. I think i'm going to add some tube that goes from the bumper to just behind the wheel. Almost like two rails that would be able to take some hits. I'm holding off right now because I might want to trim some of the fenders alittle bit. Thanks man!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Rear bumper project/ plans... [Re: onebadtrooper] #589034 04/10/05 04:28 AM
I finaly, got started on this. Its alot of work cutting with a grinder!!! I only used my chop saw once so far. <img src="/forums/images/graemlins/scared.gif" alt="" />. I still have alot of work left to do, but i've got most of the frameing done. I still have alot of grinding/ welding to do. heres some pics. [Linked Image]
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6493 MB (Peak: 0.7551 MB) Data Comp: Off Server Time: 2026-11-02 10:58:34 UTC
