Taco stalls when warm #589072 04/05/05 07:20 AM
I have a '95 Tacoma 4X4 with the v6 auto tranny. It has 150,000 miles and has always run flawlessy. Recently when the truck is warm, it will stall sometimes when going back to idle. This can even happen on the freeway when braking hard. Very scary when towing at 70 mph and the truck stalls.
I cleaned the MAF sensor and that didn't solve the problem. The dealership tried to tell me that the intake valves where dirty and that I needed a new idle adjuster.
What do you guys think. I like to do my own repairs. Do I need to replace the MAF sensor or what do I need to do to resolve this? Thanks in advance.
Re: Taco stalls when warm #589073 04/05/05 12:05 PM
does the check engine light come on while it's running?
Re: Taco stalls when warm #589074 04/05/05 02:08 PM
No the check engine light never comes on. It usually idles great also. When it does stall, its very hard to start and keep running for awhile. And then its okay until I drop back to idle again. This only happens on long (more than 100 miles) trips.
Re: Taco stalls when warm #589075 04/05/05 11:36 PM
CraShYota Offline
whens the last time your spark plugs were changed?
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: Taco stalls when warm [Re: CraShYota] #589076 04/06/05 05:17 AM
Spark plugs changed about 5K miles ago.
Re: Taco stalls when warm #589077 04/07/05 01:57 AM
bard Offline
Try cleaning the IAC and EGR. Either one will fubar your idle.
Re: Taco stalls when warm #589078 04/07/05 03:17 AM
hairytaco Offline
Check for all the simple things first. you need air, fuel and spark to run so check your air cleaner, fuel filter, battery connections, spark plugs, plug wires and distributer. By process of elimination, you will get 'er done. <img src="/forums/images/graemlins/evil.gif" alt="" />
2008 Tacoma 4x4 6spd manual SR5 TRD
Re: Taco stalls when warm #589079 04/13/05 04:24 PM
Have you learned any more about the stalling? Our 96 tacoma 2 wheel drive, manual trans. does something similar so we are looking for solution also. Both o-2 sensors have been replaced, thought it was fixed, then it shut down again on freeway after traveling around 55 miles from home. So now trying to track down the endless switches and sensors that could be related. This truck has high mileage too, even trying to do own repairs, these little sensors and things are very expensive. Any suggestion appreciated.
Re: Taco stalls when warm #589080 04/18/05 05:58 AM
Now its not doing it anymore. I have been on 3 long trips 200 miles at a time and it hasn't re appeared. On the long trips is usually when I have the prob.
Re: Taco stalls when warm #589081 04/18/05 01:47 PM
hairytaco Offline
What did you do to it to make it stop?
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6234 MB (Peak: 0.7243 MB) Data Comp: Off Server Time: 2026-06-13 12:57:18 UTC
