Page 5 of 6 1 2 3 4 5 6
Re: Locker in Front first? [Re: BigJim] #589357 04/09/05 04:18 PM
JeePete Offline
Congratulatons, and Dang, you ARE older than dirt! I checked on that other fella and he's not near as old as I was thinkin'. you've got him beat by a decade at least! I won't comment on your personal problem, (well, not a problem if you don't want sex.) but I will tell you I was born in Ft. Myers, FL In Dec 1956. That's right, 48 years on the face of the Earth! And I still don't know what I want to be when I grow up! <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Locker in Front first? [Re: JeePete] #589358 04/10/05 03:39 AM
HAHA will we ever?
Re: Locker in Front first? [Re: AZPetrak] #589359 04/11/05 06:21 AM
my 98 tj came witha d44 in the rear and 30 up front.. when i blew out the ring gear on my d44 i drove in 4 high for about a month so basiclly just on the d30 .. and it did apsolutly no harm waht so ever.. i also have dana 30 front and rear in my 83 s-10 and it has no problems with breaking what so ever so take that for what its worth
Re: Locker in Front first? #589360 04/12/05 11:34 PM
A
AZPetrak Offline OP
I have decided on 3 options that I am (1)either going to put a Aussie locker in front, and a cheap limited slip in the rear, (2) try to find a junk yard ford8.8 re-build it and put a Aussie in it or(3) buy an ARB for the front and leave the rear open. In either case I will be re-gearing to 4.10s at the same time, so it will be a couple of months before I can afford installation.
2007 4x4 Tacoma Dbl Cab with TDR and rear locker - stock for now
2001 Wrangler Sport - sold
1998 Rodeo S 4x4 - traded in
Re: Locker in Front first? [Re: AZPetrak] #589361 04/12/05 11:46 PM
If i were you, I would put a locker in the rear before the front. The rear do most of the pushing when going forward.
Re: Locker in Front first? #589362 04/13/05 03:47 PM
But the front does a dern fine job of pulling up and over obstacles...True full time front wheel drive would be really nice. I'm not sure which way I'd go if I had to do just one, but I think the front. Just my .02.
Re: Locker in Front first? #589363 04/13/05 07:08 PM
valleycat Offline
i have a rear tire off the ground about as often as a front, if not more. which sucks for me because my xj is open at both ends. i'm not sure which end i would lock if i was buying one locker. i'd probably do the arb front if it was an option. then i'd weld the 35 carrier and see how long it lasts.
by the way christian, i saw some rangers at glendale auto wrecking 623.939.5932 when i was getting my f150 hubs and rotors. you might want to call them and ask about an 8.8. don't call driven. they are f'ing expensive.
Re: Locker in Front first? [Re: valleycat] #589364 04/13/05 08:00 PM
I kinda like my selectable locker. Its called an ebrake. Since I have a 99 TJ with the D35 running 33" tires I am reluctant to aquire too much traction in any givin situation. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: Locker in Front first? #589365 04/14/05 12:53 AM
Sweet.. and I heard they're actuated by cornbread so you know it won't let you down. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Locker in Front first? #589366 04/19/05 03:50 PM
A
AZPetrak Offline OP
This is why I am probably going to go with an ARB in front, and a limited slip in rear. With limited slip in rear a little e-brake trick can help. I am not sure it does much good without at least limited slip though.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.010s) Memory: 0.6299 MB (Peak: 0.7319 MB) Data Comp: Off Server Time: 2026-07-16 08:42:30 UTC
