Bad serpentine belt tensioner and alternator, mud to blame? #589595 04/06/05 03:55 PM
TeaQue Offline OP
I went through quite a bit of mud a few weeks ago and afterwards I drove my truck around for a few days before cleaning it.
My truck started emitting this god awful noise that sounded like a bearing so I took it to a shop and they said it was my serpentine belt tensioner as well as my alternator.
Could mud have done this? How do you guys clean your motor after getting covered in mud? All I had access to was a hose and I did it when my truck was cold.
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Cheap Pilot Fog lights
Re: Bad serpentine belt tensioner and alternator, mud to blame? [Re: TeaQue] #589596 04/06/05 04:12 PM
Scottie2113 Offline
Mine did that same thing. I tried tightening the belt, but that didn't really change anything. Mine usually goes away once it runs for a while. Anyway, if you look behind the passenger side wheel where that rubber splash gaurd goes around the shock absorber and other steering components, you can see right through the opening and what do you see: the alternator. To be honest, it is in a really bad spot for mud and water to wreck it and destroy the bearings. I don't know that much, but if I was a betting man, I would say that that could be the reason. Mine makes a slight noise after sitting for a while, but once run a while the noise goes away. My noise is usually only when large electrical demand is put on the alternator, like the head lights. I haven't found a way to solve this problem of mud and water wrecking alternator bearings, but maybe bretwalda can help us out b/c he goes through more of that stuff with his Gen II than anyone I know <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
On the Gen I its up high so it stays clean and dry <img src="/forums/images/graemlins/smile.gif" alt="" />
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Bad serpentine belt tensioner and alternator, mud to blame? [Re: Scottie2113] #589597 04/06/05 04:42 PM
stony-man Offline
The alt is on top of my '92 GenII as well...it's one of the things I like better about mine than the wife's '95. Several times over the years, my tensioner/pullies got a little noisy, and I shot some of that Zep lube stuff into the pulleys as best I could...it quieted them right down. There may be valid reasons why you SHOULDN'T do this, but I had my Monty about a year when they did this the first time, and there was only 20k on the thing...the mechanic from Mitsu said I could either replace them, or just "squirt them occaisionally"...he did it to show me how, and they quieted right up. I probably do it once every year now.
Re: Bad serpentine belt tensioner and alternator, mud to blame? [Re: stony-man] #589598 10/08/11 10:28 AM
samsith Offline
i guess you don't need to blame the mud. just replace you serpentine belt or radiator. actually it is easy to do it. i have found automd where it will guide you on [color:"black"]how to replace a serpentine belt[/color] is easy.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6035 MB (Peak: 0.6611 MB) Data Comp: Off Server Time: 2026-11-16 03:32:55 UTC
