Does the 3.4 have a #589665 04/06/05 07:47 PM
urso8up Offline OP
On a 3.4 l T100 does the water pump have an oil cooler in it???
1998 T100 4x4 3 body lift 4 procomp suspension 15x10 steel wheels and 35x12.50x15 Baja Claws
http://www.cardomain.com/id/urso8up
Re: Does the 3.4 have a [Re: urso8up] #589666 04/06/05 09:01 PM
ErikB Offline
Toyota Moderator
It has one, but its not in the water pump. The oil cooler is the tuna can sized thing on the driver's side of the engine block with coolant lines going to it and big bolt through the center.
http://home.4x4wire.com/erik
Re: Does the 3.4 have a [Re: ErikB] #589667 04/06/05 10:32 PM
urso8up Offline OP
but from what i have heard Toyota makes two differnt water pumps one wit hthe fitting and one without does that make sense???
I am guesing mine has the cooler fitting.
I am going to smack the parts guy at toyota he is no help to me what so ever
Re: Does the 3.4 have a [Re: urso8up] #589668 04/07/05 04:14 AM
JohnF Offline
The local dealer told me the 2wd T's had no oil cooler and one less hose connector on the water pump. He told me this when I stopped to pick up the water pump I had ordered for my 4x4 T, he got the wrong one even with my VIN...
Re: Does the 3.4 have a [Re: urso8up] #589669 04/07/05 05:17 AM
surlynkid Offline
2wd 3.4 t100 has a different water pump than 4wd. ask me how i know. <img src="/forums/images/graemlins/smile.gif" alt="" />
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Does the 3.4 have a [Re: JohnF] #589670 04/07/05 12:27 PM
Scott Broam Offline
??? My 2WD T has an oil cooler, like Adam described - a tuna can sized thing on the driver side to the further back than the oil filter. Granted, that's quite a ways from the water pump.
96 T100 Titan Xcab V6 2WD,Powertrax No-Slip Diff, buckets, mini-mods...
http://picasaweb.google.com/scott.broam/TruckProjects#
Re: Does the 3.4 have a [Re: Scott Broam] #589671 04/07/05 01:32 PM
urso8up Offline OP
Well I figured it ou MY 4wd 3.4l T100 Has a Oil cooler according to the to my parts guy. I changed my waterpump and timing chain and seals out yesterday it took about 2 hrs to do. Preety easy and i drove it today so i must have done something right.
Next on my list to do is Gears and look or a strait axles for a SAS
Re: Does the 3.4 have a [Re: Scott Broam] #589672 04/07/05 11:32 PM
JohnF Offline
My dealer has never been wrong before... <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6196 MB (Peak: 0.7186 MB) Data Comp: Off Server Time: 2026-05-28 02:02:34 UTC
