Control Arm bushings #590411 04/08/05 08:46 PM
bigdirtdog Offline OP
I have a 94 Xtra-Cab 4x4 pickup I would like to install new Control Arm bushing is this a tough job? or can I do myself? What shop time labor on this job? Any suggestions would be welcome. Also anybody try Corbeau sport seats?
94 xtra-cab 4x4 V6 98k, K&N intake, Custom Flowmaster exhaust, Edelbrock IAS Shocks, Cross-Drilled Vented Disc, 31x10.50 AT on American Racing wheels, Hella Headlights 90/130W and Corbeau Sports seats, Addco Sway Bars FR & RR.
Re: Control Arm bushings [Re: bigdirtdog] #590412 04/09/05 01:45 AM
willzrunna96 Offline
i did them over when i did my liftreall easy to do but u may need an alignment after. best bet is the mark the ecentric cam bolts so you can get it close. i used a ball joint press to press the old bushings out. energy suspension makes them in polyurethane but u have to reuse the metal parts
Re: Control Arm bushings [Re: bigdirtdog] #590413 04/09/05 02:48 AM
mt_goat Offline
I used a huge vice with a 3 foot cheater pipe and a BFH to press mine out. The new ones go in a lot easier than the old ones come out. Putting the control arms back on the truck by yourself is a little tricky. I finally figured out that a floor jack and a 2x4 works pretty good. I used OEM bushings.
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: Control Arm bushings [Re: mt_goat] #590414 04/09/05 02:49 AM
kewlynx Offline
IIRC, Arbitary Notion just burned his old ones out and popped in his new ones.
**ubi apis- ibi salus**
Re: Control Arm bushings [Re: kewlynx] #590415 04/09/05 04:16 AM
solarcrew Offline
<img src="/forums/images/graemlins/scared.gif" alt="" /> If the cam bolts come out of the sleeves easily,it's a piece of cake!If their rusted in,it's a P.I.T.A !!!! Good luck! <img src="/forums/images/graemlins/cheers.gif" alt="" />
87'4runner-22re,5spd
Re: Control Arm bushings [Re: bigdirtdog] #590416 04/10/05 09:22 PM
mt_goat Offline
Here's a pic of the pipe fittings I modified to press the bushings out. http://community.webshots.com/photo/185194728/185195196gFQQuE
Here's a pic of the vise I used to press them out: http://community.webshots.com/photo/185947798/185947798gIQSCg#
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6095 MB (Peak: 0.6789 MB) Data Comp: Off Server Time: 2026-06-06 14:08:52 UTC
