Page 2 of 3 1 2 3
Re: rear springs on front and 63" chevys [Re: ChrisH] #590645 04/15/05 03:11 AM
SHAD Offline OP
Well I bought the leaf springs today. I paid more than $100 for them too. They were 63" leaf springs from a 1999 chevy silverado.
They were really really clean.
They came with all the attachment bolts and the chevy shackle.
The only thing I can see different on these is the front mount bolt is slightly larger in diameter which only means I need to drill out the spring hangers a little so no biggie.
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: rear springs on front and 63" chevys [Re: SHAD] #590646 04/27/05 01:23 PM
SHAD Offline OP
A update it's taking me a while to get this done.
sky's chevy rear ubolt flip kit.
I painted it blue.
Bud Built banana shackles for running the rear springs up front. [Linked Image]
My 2000 2wd chevy silverado leaf springs
Now I need to get the rear hanger and the shackle for the swap.
I am having a hard time deciding wether to run the johnny flex joint shackle hanger in the back or just a regular bushing and a shackle.
86 Toyota 4 runner
My cardomain page
Re: rear springs on front and 63" chevys [Re: SHAD] #590647 05/03/05 03:13 AM
SHAD Offline OP
Ordered up a hidden hitch winch mount plate for my magnum 9000 winch today.
I bought it from JC Whitney for $42.99 online it was like $51 shipped.
I also got my front licence plate today pretty trick:
Here's the ford f250 shock mounts:
Rancho 5012 shocks:
collapsed
extended
My buddy can't squeeze me in untill next week to get the spring hangers and stuff welded on so I have to wait to get it done.
86 Toyota 4 runner
My cardomain page
Re: rear springs on front and 63" chevys [Re: SHAD] #590648 07/11/05 02:47 PM
SHAD Offline OP
Some more info I just completed my 2000 silverado 63" leaf spring install last night.
The front spring bushing has a 5/8" diameter bolt hole so you will need to drill your spring hanger to match.
The rear leaf bushing is still 9/16" so that hasn't changed.
Also the center pin on the leaf pack is a little larger than 5/8" so the ubolt plate center hole will need to be reamed out slightly to fit.
I have a semi light flatbed on my truck 300-350 lbs the 00 silverado pack I am using is a 2 leaf pack with a overload.
I am using bud built 8" shackles and the spring pack makes the truck sit level with the front and I believe the front springs are 4" procomp springs they have sagged some and are actually about 3" now.
I am able to completely stuff my rear tires they touch my flatbed tray.
86 Toyota 4 runner
My cardomain page
Re: rear springs on front and 63" chevys [Re: SHAD] #590649 07/11/05 03:32 PM
SHAD Offline OP
some pics:
It's a little muddy I had to test it out in the back yard of my buddies house he had a few trails to try it on.
86 Toyota 4 runner
My cardomain page
Re: rear springs on front and 63" chevys [Re: SHAD] #590650 07/12/05 03:55 AM
SHAD Offline OP
Better pics this morning after I washed and painted the hangers.
I now have a nice Class III hitch welded on.
My buddy gave me one for helping him out on his truck wiring.
Test fitted my Multi-mount magnum 9000lb winch
I have some electrical quick disconnects on order that's all I am waiting on to wire this up so I can use it on the back if needed.
86 Toyota 4 runner
My cardomain page
Re: rear springs on front and 63" chevys [Re: SHAD] #590651 07/12/05 05:17 AM
carter Offline
Got any pics of the rears up front? Are you running the stock front spring hanger? If so, how's the pinion/caster with the longer shackles?
Mike Carter
85 & 86 4Runners
My Website
Re: rear springs on front and 63" chevys [Re: carter] #590652 07/12/05 12:30 PM
SHAD Offline OP
Nope still waiting on my springs. They are currently at the spring shop being done.
Worse case I might have to run a angle shim to correct it.
I know the rear I need about a 3-4 deg shim. I checked the DS angle after the chevy swap and the pinion is at 10 deg and the driver shaft is now 17 deg.
86 Toyota 4 runner
My cardomain page
Re: rear springs on front and 63" chevys [Re: SHAD] #590653 12/05/05 12:40 AM
SHAD Offline OP
Decided against doing rears on front.
I ended up going with 5" skyjacker soft ride springs for the front.
Also put in new a new sky-manufacting front u-bolt flip kit and installed my ford F-250 shock towers and my Rancho RS5012 shocks on the front.
I am pulling the small short leaf on the bottom of the sky-jacker leaf pack for additional flex.
I only went this route because it's a daily driver and I didn't feel like making a new front spring hanger and having to fab up a longer front driveshaft.
86 Toyota 4 runner
My cardomain page
Re: rear springs on front and 63" chevys [Re: SHAD] #590654 12/05/05 02:09 AM
87Toy4x4 Offline
i just noticed your winch on the back. you dont keep it on there all the time do you? b/c if you got rear ended or backed into something you would be sol.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6489 MB (Peak: 0.7588 MB) Data Comp: Off Server Time: 2026-06-17 12:56:19 UTC
